07-19-2017, 05:01 PM | #1 |
Drives: Camaro 2017 1LE Join Date: Feb 2016
the famous clicking noise when turning
so mine started doing it when turning to the right , click click what is the final verdict for resolution? just clean ?
07-19-2017, 05:03 PM | #2 |
Drives: 2106 SS Join Date: Aug 2016
Turning signal.. lol just kidding
Sent from my SM-G935V using Tapatalk |
07-19-2017, 05:04 PM | #3 |
Retired from Car mfrs....
Tighten lugs to 140 ft lbs....
07-19-2017, 05:42 PM | #4 |
this might be 1le specific ?
07-19-2017, 07:32 PM | #5 | |
@SS_1LE
Drives: 2017 SS 1LE Join Date: Mar 2017
Mine was nowhere near spec from the factory and thats why mine clicked. Tightened them and it went away.
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S |
07-19-2017, 07:35 PM | #6 |
07-20-2017, 07:24 AM | #7 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
Mine went away after a clean. Had the dealer do it and it has been 6 months without returning.
07-20-2017, 07:34 AM | #8 |
Drives: None Join Date: May 2017
07-08-2019, 01:02 AM | #9 |
Drives: Chevrolet Camaro 1SS Join Date: Apr 2019
I have this same problem. Almost resembles the sound of having a screw in my left front tire and the noise speeds up the faster the tire rotates. I only notice it when turning right when my window is down. I torqued my lugs to 140 and the noise is still there. I plan on making a trip to the dealer, but if someone has a solution I would rather not make the visit.. Did you ever resolve the problem?
07-08-2019, 05:21 AM | #10 |
Drives: 2018 Camaro ss 1le, 2010 VW GTI Join Date: Apr 2019
If you have a 1LE it is most likely the bolt for the sway bar. Mine was fixed under warranty, all they do is retighten to proper torque spec and add loctite
07-08-2019, 09:07 AM | #11 |
Drives: 2018 SS 1LE Join Date: Dec 2014
Had mine fixed at dealer, they claimed they cleaned hub and retighten the lugs and noise was gone.
07-08-2019, 10:36 AM | #12 | ||
Thank you Al Oppenheiser!
This. The problem is oxidation that grows at the hub/wheel interface. It becomes a fulcrum and causes the wheel to rock & make the clicking noise as it rotates when under cornering loads. DIY solution: 1. remove wheel 2. clean wheel & hub mating surfaces with a wire brush... scrub off the oxidation. 3. wipe both wheel and hub clean with a good cleaning solution. You need to get them very clean. 4. apply a VERY THIN layer of white lithium grease to the mating surfaces. 5. re-mount wheel and torque to 140 ft-lbs. |
08-09-2019, 04:19 PM | #13 | |
Drives: Chevy Corvette Join Date: Apr 2019
Thank you for that write up! My car has 12k miles so I was a bit skeptical that this would be the issue. I figured I would try it since I really didn’t want to go to the dealership, tried this method and it got rid of the annoying clicking issues I was having. |
09-25-2019, 08:42 PM | #14 |
Drives: 2018 Chevy Camaro ZL1 convertible Join Date: Apr 2019
Thanks to the guys above in this thread. Finally pulled my wheels, cleaned and torqued to spec and no more click. I didn't check the torque first, but just from breaking them loose, there's no way they were all at spec.
