03-21-2020, 09:29 AM | #15 |
Drives: 14 SS Join Date: May 2019
Man, that sounds great.
03-21-2020, 10:43 AM | #16 |
Drives: 2015 2SS A6 Commemorative Edition Join Date: Nov 2019
Sounds great! Nice lope
03-21-2020, 11:15 AM | #17 |
Tune almost complete. The last revision Ryan sent made a huge difference. The shifts are so much better now, even better than my last tune when bolt on. No lurching forward on the shift, just quick, firm, and done. The top end is incredible. It actually scared me on my first WOT pull lol because I wasn't expecting it. Then I did 7 more.
I am not used to my tuner wanting datalog after datalog. I think this is the 6th one I am sending him, which makes me very happy. Coolant temps are only a couple degrees hotter than previous and he got the fan activation dialed in. But I do notice underhood temps are crazy now. Both my O2 extensions, the plastic looming melted completely off. Those were not touched during the cam swap, so I obviously have increased heat now. I'm going to get some heat wrap today and reroute them. I also need a hood vent.
03-28-2020, 03:24 PM | #18 | |
UPDATE:
Updating the thread with a new Cold Start video. Ryan from GPI completed the tune a couple days ago. Tell you what, that man was amazing to work with. I think he did 7 tune revisions based on my datalogs. He listened to every request and input I gave him regarding how the car was behaving and adjusted accordingly. I am so happy with how the car is performing and will use GPI again without hesitation. Based on my mods he is estimating 450-460 rwhp. I am hoping to have it dyno'd this summer. Cold start - seems to go into closed loop idle around the 1:20 mark:
03-28-2020, 04:03 PM | #19 |
USA-1
That's awesome man! Do you have plans to add their ported/rod modded manifold? I'd bet you see another 10-15 hp. Do you have a UDP?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
03-28-2020, 04:15 PM | #20 | |
I kinda regret selling the extra intake I had from my old L99, but I will likely just pay the refundable core charge or do the exchange.
03-28-2020, 07:01 PM | #21 |
Drives: ABM #93 Join Date: Oct 2018
Sounds killer! I hope to get mine done this summer if I don’t decide to give it to my wife. I’ve been eyeing Z/28’s a lot lately.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
03-28-2020, 07:23 PM | #22 |
03-28-2020, 07:59 PM | #23 |
GPI rocks...
03-30-2020, 07:57 AM | #24 |
Congrats. GPI really does make a great cam. Can't wait to get more of these installs on the books.
03-30-2020, 03:09 PM | #25 |
Drives: 13' 1LE Join Date: Apr 2012
Niceee, sounds good. Get that rod modded unit!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
