04-10-2022, 01:54 AM | #57 |
Drives: 2018 Chevrolet Camaro 2LT Join Date: Mar 2019
I had parasitic draw that was draining the battery in 2 days. Turned out to be the bose amp not going to sleep all the time. You could hear it still hissing slightly if you listened at the soeakers after waiting 5 mins for the car to go to sleep. It didn't fo it every time sometimes it slept properly. GM replaced the amp under warrenty.
04-10-2022, 11:03 AM | #58 |
I'd also be interested to see if anyone has a more tractable testing process than the only one I can think of, hooking up a multimeter and pulling fuses one by one to see what happens in the car 5-10 minutes after shutdown. Neither the hood nor the trunk lid should prevent the systems from going into full sleep.
04-10-2022, 11:40 AM | #59 | |
Thank you Al Oppenheiser!
04-11-2022, 05:53 PM | #60 |
Drives: 2017 1LT RS V6 A8, 2020 Fusion Join Date: Jun 2017
That info and chart looks very useful. Thanks.
04-11-2022, 07:13 PM | #61 |
Ditto, thank you very much, Gunkk
04-11-2022, 08:31 PM | #62 | |
Mine started the same thing so I leave on 1.5a trickle
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 04-12-2022 at 02:25 PM. |
04-11-2022, 09:57 PM | #63 |
Well, since we know that software updates can continue for, I believe, 30 min after the power is turned off, it makes sense that such activity consumes a bit of power.
'20 ZL1 1LE A10,
04-12-2022, 02:05 PM | #64 |
04-12-2022, 02:20 PM | #65 |
Just for clarity, using a multi-meter set to DCV, negative lead on ground and positive lead on a particular fuse, the meter should read according to the chart? I'm wondering what 179mA DRAW will look like in mV?
04-12-2022, 02:25 PM | #66 |
'20 ZL1 1LE A10,
07-29-2022, 03:31 PM | #67 |
I'm still stuck. Range disconnected. Got 178-183mA draw with only the trunk open (light disconnected.) The draw changes from 178 to 183 about every second. Seems like some device is "searching" for something. I got in contact with a dealership to try to get a "spec" on "normal parasitic draw" but was unable to get an answer.
04-07-2023, 05:24 PM | #68 |
Drives: 2018 chevy camaro ss 1le Join Date: Mar 2023
Battery dead in 2 days
Someone has mentioned this before and it sounds ridiculous, but shut the wifi off in the radio settings. My car would randomly go into key learn mode, a no start situation yet the key fob worked fine to lock/ unlock/ trunk pop/ panic, even putting the key fob in the rear cup holder did nothing. Holding the start/stop button for 12 seconds took it out of the learn mode and the car started every time. 2 dealer visits with not much help, they disconnected my wireless charger, came home, the next day the car is in key learn mode. It has been over a week with wifi shut off and I have absolutely no issues. A day before I shut off the wifi I went out at night after a no start issue to see the backlight of the radio on and the power button ring lit up for well over 5 mins. There is some kind of wifi connection issue.
