08-08-2021, 09:04 PM | #225 |
Drives: 2016 2SS blue velvet w/blk stripes Join Date: Sep 2017
I already have an extra battery cable grounding the block to the chassis, but when i installed ceramic coated headers, i noticed sometimes if i have to stop and restart the car right away it barely starts, as in 9.58 volts according to my battery monitor. Should i get an extra heat shield?
Current mods. Rotofab CAI, Speed Engineering Long Tube Headers and plug wires w custom tune. Shock tower brace, ground effects, OEM brake air ducts and splash gaurd delete, 275/315 tires on 10 and 11 inch MRR wheels.
08-08-2021, 10:13 PM | #226 | |
2020 Shadow Gray 2SS
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
08-09-2021, 10:04 AM | #227 | |
Good luck and let us know how it turns out.
08-09-2021, 12:10 PM | #228 |
Drives: Former Owner '16 Camaro 2LT V6 conv Join Date: May 2021
Are there traditional flooded batteries have a vent hose like AGM? As far as I can tell, AGM batts don’t have much of an advantage besides the safety aspect. The second perk I read they have is lower maintenance, but my flooded batts have always been, quite literally, zero maintenance.
08-25-2021, 07:21 PM | #229 | |
Drives: 2018 SS 1LE Join Date: Sep 2018
Just ordered from BATTERYCABLESUSA two 24" cables, I went with the 2/0AWG wire. What is the bolt size/thread?
08-25-2021, 07:29 PM | #230 |
See this post: https://www.camaro6.com/forums/showp...&postcount=124
08-31-2021, 10:09 PM | #231 |
Update: I wired the wired it to the negative post in the engine bay and onto the engine. It did NOT fix my problem (slow crank/no crank/single click from starter solenoid I believe) :(
09-01-2021, 01:22 PM | #232 | |
Is the slow crank on a cold or a hot engine? Could you post a picture of where you connected the new ground cable if you used a different location than in this thread? Most of us with the slow crank/hot engine have had 2016 SS models. I haven't read about any 2018 models with the issue until your post. Good luck and keep us posted.
09-05-2021, 02:34 PM | #233 | |
No crank, single click I believe from the starter solenoid, when cold happened a couple days. That was the first time ever happening on a cold start. Slow/no crank(single click) is happening on warm/hot start. I connected the new ground at the same location as the pic a few posts above. There are days where it starts up with no problem. But these symptoms has been more frequent as time goes by. I need to load test the battery and connect the extra ground wire I bought in the trunk. |
09-05-2021, 03:10 PM | #234 | |
09-05-2021, 03:24 PM | #235 |
09-05-2021, 03:25 PM | #236 |
09-08-2021, 03:34 PM | #237 |
UPDATE: I went to Autozone and had them test my battery while it’s still in the car. It turns out to be a bad battery according to their device.
09-08-2021, 04:56 PM | #238 |
Here is hoping that new battery added to the ground cable(s) you've added puts your car right and your starting woes are behind you.
