Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 02-13-2013, 02:13 PM   #29
Richy_Rich
FAVOR
Richy_Rich's Avatar
Drives: Many Different Rides
EXCELLENT!!!
Please be kind when you drive; thank you.
Richy_Rich is offline   Reply With Quote
Old 02-26-2013, 08:12 PM   #30
yellow69z28rs
Drives: 2013 ZL1 Convertible Black
Send a message via AIM to yellow69z28rs
Originally Posted by Matt @ FSP View Post
Nice product bump.. Will try to get a better ETA on these
Any news?
JRE 750 HP package
Rag Top Rob
yellow69z28rs is offline   Reply With Quote
Old 02-26-2013, 08:33 PM   #31
360ss
ZL1 NIGHTMARES!!!
360ss's Avatar
Drives: LACS+CHEVYS
Thumbs up Agreed!!
[QUOTE=Matt @ FSP;6074150]Not taking it as argumentative, I'm glad that you have asked such a question actually.
That question can be posed about pretty much any upgrade on any car. The car already comes with a suspension, why replace it? The answer is plain and simple: pure performance.
Flatter cornering, less deflection in the suspension joints and more consistent grip levels associated with the contact patch being planted on the pavement. The OEM suspension is fantastic, no doubt about it. But there are many concessions made in the interest of mass production and cost cutting that leave there more to be desired. Plus most cars from the factory are set up relatively soft which can overload the outside tires in a turn. One way to get the car to perform better is to simply get each tire perform more equal work when going around a turn and you do that by stiffening things up a big with bigger anti-roll bars and coilovers with upgrade spring rates, to name a few. This is stuff that the factory can not install for a variety of reasons, some having to do with costs and other associated with perceived ride quality.
The adjustable coilovers in this thread actually RETAIN the full functioning Mag ride system that you bought the ZL1 for but makes it lighter weight, and adds ride height adjustability and stiffer spring rates to hold the car up a bit more in turns and lower it to the ground for a slightly better aero profile and flatter cornering. All of this contributes towards more grip and better performance.
Any more questions please ask!
13zl1 #251 NOTHING ELSE MATTER
360ss is offline   Reply With Quote
Old 02-26-2013, 08:33 PM   #32
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
So if the shocks are adjustable, how do you take in account of the Ride hieght bar needed for the sensor? If that's to long or short this will give the computer inaccurate data and charge/decharge the shocks incorrect.
armysig is offline   Reply With Quote
Old 02-26-2013, 09:59 PM   #33
trademaster
Drives: 12 MP4-12C, 16 Quattroporte
For the few of you worried that this would not offer a significant increase in performance, do some reading on the inherent pros and cons of coilovers vs struts/springs. Magnetic ride control can continually adjust damping, maximizing the potential performance of the strut/spring, but that maximum is well below the maximum performance of a well designed coilover. OEM tends to stay away from coilovers because strut setups are easier and cheaper to deal with both in original manufacturing and in servicing, but the coilover is superior for tarmac performance. The stock ZL1 mag suspension is great. Assuming these coilovers are dialed in and optimized for the mag ride, they will bump that great up to absolutely incredible. A friend of mine has the KW Variant 3 coilovers on his CTS-V and that thing is a downright joy to put into corners.
trademaster is offline   Reply With Quote
Old 02-27-2013, 12:26 AM   #34
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
I wanna see the stance of the Z with these
1990 IROC-Z Vert LS
1996 SS Vert LT4
1992 Z28 Z03 T5
1992 Z28 Z03 L98
2018 Sierra Denali 6.2
1997 Z28 Z4C
1995 Z28
Jer4251 is offline   Reply With Quote
Old 02-28-2013, 11:12 AM   #35
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Well I'm interested if not only for the ride height adjustability, and added static stiffness. My car is a 4x4 in my view (height wise).
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 05-12-2013, 02:27 AM   #36
2012-1822
2012-1822's Avatar
Drives: Black ZL1
Originally Posted by UBNZO6D View Post
So then why put the post up ?
Seriously?
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 05-12-2013, 02:35 AM   #37
2012-1822
2012-1822's Avatar
Drives: Black ZL1
You are demanding two polar opposites out of the same setup... Will they work for both applications, YES... Would it be ideal for both applications, no. If you are a street car that then goes to the drag or road course, you'll be fine with the standard coilovers. If you are looking to build a purpose built track car, pick one of the two and then go that direction.
Not trying to be negative at all, but remember that the ZL1 is purpose built to do it all and that is why I bought it. So when more info on these things comes out I'll definitely be looking. However, when it comes to any mod, I won't do a mod that ever takes away from this car being a ZL1 and what makes it so special. That is absolutely no knock on this product, in fact the exact opposite because this product incorporates what it does and the MR. I suppose then my statement is aimed to the general after market in saying make sure what you want to sell me elevates the ZL1 and doesn't turn it into a SS with ground effects.
Old 07-25-2013, 03:15 PM   #38
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Bump! Did these ever come out??
KKreme15 is offline   Reply With Quote
Old 07-25-2013, 05:25 PM   #39
2012-1822
2012-1822's Avatar
Drives: Black ZL1
Don't think so, last I read ,Pfadt's website said just get coilovers and abandon the Mag ride, could be wrong about that interpretation, but I don't want to give up my Mag ride.
Old 07-26-2013, 12:39 PM   #40
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Bummer. I need these
Old 07-26-2013, 01:14 PM   #41
EFI
EFI's Avatar
Drives: something faster than you
This is true, but many people are paying the ZL1 premium for its handling performance (among other things). It seems silly to pay all this extra money for the ZL1's features only to throw them out and pay another few grand on top of new suspension.
At this point, might as well get an SS and with the money saved on MSRP you put in some killer suspension and engine modifications. At least then you are only throwing away a crappy suspension while saving alot for money.
It's like spending extra money on an expensive badass computer from Alienware only to completely gut it out and put in new top of the line components. Might as well get a basic desktop and upgrade that with the same components.
EFI is offline   Reply With Quote
Old 07-27-2013, 10:26 AM   #42
zl1bro
Drives: 2013 ZL1 M6 SIM AGM mono stripe
So these have never been brought to market?
zl1bro is offline   Reply With Quote
