Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 08-02-2017, 02:43 PM   #1
Sooner Cole
Sooner Cole's Avatar
Drives: 2018 ZL1-1LE
Headers?
Has anyone added headers? I'm curious what Brand, with or without cats and factory muffler w/NPP or aftermarket mufflers. Having hard time finding ZL1 specific headers. Most just say 2016-newer Camaro SS.
My first car was a '76 Camaro. I've been hooked ever since.
Sooner Cole is offline   Reply With Quote
Old 08-02-2017, 07:48 PM   #2
IKILLEDSUPERMAN_ZL1
Drives: 2017 ZL1 Camaro
I believe they are the same.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 08-02-2017, 08:12 PM   #3
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
There are no specific ZL1 headers to my knowledge. All the headers that work with the SS will work on the ZL1.
djfury05 is offline   Reply With Quote
Old 08-07-2017, 02:27 PM   #4
DanielB
Drives: 2002 Camaro SS
2" Stainless Works, no cats, with full Stainless works catback here:
https://www.facebook.com/whiteheadmo...8735096170430/
DanielB is offline   Reply With Quote
Old 08-07-2017, 04:08 PM   #5
BlaqWhole
BlaqWhole's Avatar
Drives: 2017 Camaro ZL1 A10
TSP has them. And as mentioned, the SS headers will also work on the ZL1. I plan to get a set of TSP 2 inch catless at the end of this week. I already have a catback that deletes the exhaust valves and I'm pretty happy with it! The headers should make it even nicer!!
2017 Camaro ZL-1 A10 - Roto-Fab cai - Katech ported TB - MBRP Race catback - VTC!!
2017 Challenger Hellcat M6 - Legmaker CAI - MM ported TB - Sprint Booster!!
2012 BMW X5 50i!!
Saving the world...1 hp at a time!!
Old 08-07-2017, 04:10 PM   #6
BlaqWhole
BlaqWhole's Avatar
Did you do the install? If so, how difficult was it compared to the 5th Gen Camaros?
2012 BMW X5 50i!!
Old 08-08-2017, 12:22 PM   #7
DanielB
I did not, but from what I understand it was a little bit more difficult than a 5th gen.
2015 GMC CC 6.2 | 2002 SS #2847 - Brembo - Koni - Recaro | 2000 SS #3825 - Huron Speed Turbo Build | 2000 Z28
Old 08-08-2017, 12:26 PM   #8
Can'tHave2MuchHP
God - Family - Country
Can'tHave2MuchHP's Avatar
Drives: 2018 Camaro ZL1 A10 Coupe in White
LT4 cars are tighter than the previous G5 Camaro and C6 Vettes, but still doable.
Top quality headers are American Racing Headers (ARH) and Kooks, with the rest falling slightly behind.
Old 08-08-2017, 01:06 PM   #9
USP45
ARH 2" primaries will drop in from top on passenger side once you remove the heat shield from starter to drop in and then put it back on. But make sure to put heat shield back on once header loosely fastened to head, if you torque it down you will not be able to get to the 10mm (head) bolts to put the heat shield back on.
For drivers side have to go up through bottom. Remove steering link and remove the bracket holding plug that front O2 sensor plugs into. My car is approximately 18" off ground and it went in relatively easily. It does help to remove valve cover on passenger side when sliding header in from the top, but may not be necessary with 1-7/8 primaries.
USP45 is offline   Reply With Quote
Old 08-08-2017, 01:40 PM   #10
YLWJKT
Drives: 2017 ZL1
If you're not planning on future boost increases or cam what would be better; 1-7/8" or 2"?
YLWJKT is offline   Reply With Quote
Old 08-08-2017, 02:43 PM   #11
BlaqWhole
BlaqWhole's Avatar
Did you have to remove the actual starter, steering shaft, or any of the engine mounts?
2012 BMW X5 50i!!
Old 08-08-2017, 02:56 PM   #12
USP45
No, both engine mounts stayed bolted up. starter stayed in place, just had to remove the heat shield to slip passenger header in (tried with shield in place, no-go). I already had steering shaft out, but I am pretty sure you would need to remove it anyways.
Now, this is for the ARH 2" primary headers, something like the Kooks or Stainless Works could be a little different depending on how the tubing is bent, I'm just not sure. I really did not think it was difficult, but everyone has different mechanical experiences.
Old 08-08-2017, 11:38 PM   #13
TheElementalCashew
TheElementalCashew's Avatar
Drives: 2017 ZL1
I ordered Kooks 2" headers with green cats in April. Still haven't seen them or heard when they will ship. Looks like I'll be missing my install date in September.
2017 Camaro ZL1, Nightfall Gray Metallic: M6, PDR, exposed CF, navigation, sunroof
Mods: Rotofab CAI, Tony Mamo TB, Kooks headers (green cats), 18% LPE lower pulley, E85/FlexFuel sensor. BC Forged RS41s (19x10, 19x12)/Nitto NT01s (305/325)
Dyno: E40: 661whp/703wtq, 93: 633whp/674wtq
Coming soon: Whipple 2.9l and fuel.
TheElementalCashew is offline   Reply With Quote
Old 08-09-2017, 05:07 PM   #14
Jason 98 TA
Drives: Camaro
Texas Speed has long tubes in stock. I'll try to track test and dyno test soon!
Jason 98 TA is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
