Old 09-12-2018, 11:31 PM   #1
Ricco
Ricco's Avatar
Drives: 2018 ZL1 Vert A10
ZL1 1LE Caliper part numbers
I understood earlier on that the ZL1 and ZL1 1LE calipers were different and had different rotor sizes.. According to the Chevrolet site, they both have the same size rotors and I am therefore assuming the same calipers (just a different colour).
The regular ZL1 calipers seem to run about $250 each, which isnt much more than it would cost to have my stock calipers powder coated (like properly done), but I cant nail down the part numbers for the 1LE calipers.
Can anyone confirm that the ZL1 1LE calipers will interchange with a regular ZL1, and if so, what are the part numbers?
Thanks!
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Previous cars in chronological order
2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta
Ricco is offline   Reply With Quote
Old 09-13-2018, 07:11 AM   #2
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
The ZL1 and ZL1 1LE brakes (J6H code) are identical other than caliper color. Someone can verify these...
RF A1Z Caliper 84229191
LF A1Z Caliper 84229190
RR A1Z Caliper 84212290
LR A1Z Caliper 84212289
RUQWIKR is offline   Reply With Quote
Old 09-14-2018, 07:05 AM   #3
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
You're correct, those should be the PNs for the red ZL1 1LE calipers. PNs for the gunmetal ZL1 calipers should be:
FL: 84229171
FR: 84229172
RL: 84022228
RR: 84022227
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 09-14-2018, 07:43 AM   #4
Ricco
Ricco's Avatar
Thanks guys. Can you confirm they are identical with the exception of the color?
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Old 09-14-2018, 08:21 AM   #5
Ricco
Ricco's Avatar
Thanks - Seems like the site I was looking at had the rears listed as fronts. Seems that the rears run about $250 and fronts are a bit over $500 (each).
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Old 09-14-2018, 09:48 AM   #6
Alpha1BC
Alpha1BC's Avatar
Yup, only difference between them is color and decal.
2017 SS 1LE.
Old 09-24-2018, 08:17 PM   #7
DarkneSS.
Drives: 2016 2SS
On that note,and not to jack the thread. Will CTS V calipers and brakes work?
DarkneSS. is offline   Reply With Quote
Old 09-25-2018, 08:04 AM   #8
Alpha1BC
Alpha1BC's Avatar
From what year? In theory over the last 3 generations of V the different rotor diameter and caliper sizes currently available on the Camaro are there, but I have no idea if the rotor/caliper offsets will be a direct bolt-on fit for the Camaro hub/knuckle offsets.
What's your motivation to get CTS-V calipers instead of the other sizes of Camaro calipers? Aesthetics? Easier to find or cheaper than Camaro parts?
2017 SS 1LE.
Old 09-25-2018, 08:51 AM   #9
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
V3 CTS-V (16-current) use J6H brakes (same as 17+ ZL1) with same rotor, pad, and calipers (not including the colors / logos). As FYI, J57 front calipers (Z28, C6/C7Z's with CCB's) are the same as J6H (not including the colors / logos). If you look at the back side of the J6H front rotor, you can see the machined slot for the CCB pad wear sensor to snap into.
Old 10-12-2018, 08:15 AM   #10
DarkneSS.
Drives: 2016 2SS
Thanks for the info. Just priced 1LE calipers and the dealer quoted me $900.00 plus for the front each. Ouch!
Old 10-12-2018, 08:24 AM   #11
DarkneSS.
Drives: 2016 2SS
Can anyone verify 2016 CTSV caliper part numbers?
Old 10-12-2018, 09:20 AM   #12
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
There here, note the "replaced by" part numbers in the description: https://www.gmpartsgiant.com/parts-l...per-front.html
You can choose colors called Gold, Gunmetal, or Red.
