Old 07-27-2018, 10:47 AM   #1
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
z28 carbon disc for zl1
Are the rotors compatible with the 6 gen zl1 in front and if you run the z28 calipers in back?
any swap info out there?
Old 07-27-2018, 11:40 AM   #2
S2K+1LE
Drives: 17 SS 1LE | 07 S2K
They absolutely are not compatible with the pads that ship for use with steel rotors.
Other than that, no real reason why it shouldn't work according to the measurements and bolt pattern. There's a vendor selling an upgrade with the Z28 discs and ZL1 calipers, so that should pretty effectively answer that.
S2K+1LE is offline   Reply With Quote
Old 07-27-2018, 11:41 AM   #3
S2K+1LE
Actually there IS *at least* one reason it might not, if the hub carrier is different.
Old 08-26-2018, 05:06 PM   #4
RabbitZL1
Drives: 2018 Camaro ZL1
I’ve been looking at this very closely. I think you can buy a z28 front rotor and swap hats and it will work. But no one wants to buy a 1200 dollar rotor to try it lol. And as for the rears yes it’s just z28 rotor and caliper.
RabbitZL1 is offline   Reply With Quote
