Old 08-12-2018, 09:45 PM   #15
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
I think that's true, since IIRC GS and Z06 use the same steel brakes as SS 1LE.
R3ctivision is offline   Reply With Quote
Old 08-22-2018, 09:21 PM   #16
Dave-ROR
Drives: A few
~$325 shipped per rotor (to Florida at least)using the AC Delco part numbers with the 5% off code (MMJL811).
Not bad.
Did anyone determine whether or not the brake caliper bolts are actually TTY on the Gen 6 1LE? If so, does anyone know the part number?
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback
Too many cars.. never.
Dave-ROR is offline   Reply With Quote
Old 08-22-2018, 11:21 PM   #17
R3ctivision
1LE Convert
Drives: 2018 ZLE
Still waiting on the part numbers here.
Old 08-23-2018, 07:21 AM   #18
nasbagoat
Drives: 17 SW 1LE
I don't know what you are waiting for.... The gm part numbers are on page 1 of this thread and the DBA ring part #'s are in the thread titled as such.
nasbagoat is offline   Reply With Quote
Old 08-23-2018, 10:26 AM   #19
R3ctivision
1LE Convert
Drives: 2018 ZLE
Sorry for not being clear. Talking about part numbers for the bolts to mount the calipers to the knuckle.
Old 08-23-2018, 12:48 PM   #20
nasbagoat
Drives: 17 SW 1LE
11570092
Old 08-23-2018, 05:04 PM   #21
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Not bad.
The instructions I have say they are TTA,
First Pass: 150 N-m (111 lb ft)
Final Pass: 15-30 degrees
but they don't say to use new ones, just clean and re-apply thread locker. I used new ones to be on the safe side. The new ones come with a dry thread locker on them already.
Old 08-23-2018, 06:48 PM   #22
R3ctivision
1LE Convert
Drives: 2018 ZLE
Interesting. Are you sure they aren't TTA? Is this the official GM service guide?
Old 08-24-2018, 08:00 AM   #23
nasbagoat
Drives: 17 SW 1LE
I just looked through the service manual and there is no listed procedure for J6M(1LE) or J6H(zl1) listed. However on standard camaro brembos the procedure deos not call for replacement of hardware.
Old 08-24-2018, 08:11 AM   #24
carguy55
carguy55's Avatar
I think TTA is closer to what it is, but I'm no expert. My info comes from the Front Brake Caliper Replacement (J6M) Installation Procedure and also the 6-piston Brembo install instructions.
Old 08-24-2018, 12:53 PM   #25
Dave-ROR
Drives: A few
Yeah that sounds like TTA vs TTY.
I have new bolts on the way anyways. Good to have spares I guess.
-Dave
Old 01-21-2019, 06:44 PM   #26
Rbah
Drives: 2018 Camaro SS 1LE
Curious if anyone has tried the 2012-2015 ZL1 front rotors in an 18 SS 1LE. Appears they both share the same 6 piston, 370mm rotor setup. AC Delco part number 177-1145/6 and it prices out a little cheaper
Rbah is offline   Reply With Quote
Old 01-22-2019, 11:22 AM   #27
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
The hats are different but same rings
Old 01-25-2019, 07:07 PM   #28
carguy55
carguy55's Avatar
Like was said they have different hats. You could save $60 per rotor by buying the ones you have listed and then changing the hats, if in fact the rotors are the same. Any volunteers to try it?
