06-29-2021, 08:50 PM | #239 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
06-30-2021, 10:16 AM | #240 |
im at -3 front without camber plates just the spl parts but i just ordered up a mcs 1 way kit this morning with the vorshlag camber plates cant wait!
07-12-2021, 12:51 PM | #241 |
talked to them this morning should be done in a week or so!
06-16-2022, 04:35 PM | #242 |
Drives: 2022 ZL1(FEA suspension) Rapid Blue Join Date: Apr 2019
Just a quick question. How are you guys making the adjustments? Do you simply jack the corner up, loosen the 3 nuts and then what? Is there enough movement that you can grab the strut and move it by hand, or do you need to use a block of wood and a hammer? Or some other method.
I've got these plates, and I'll be damned if I can get them to slide! Am I doing something wrong? |
06-16-2022, 04:43 PM | #243 |
ive never touched mine since i got them installed but i saw my alignment guy loose some stuff under neath and then take a hammer and a block of wood to get them to move
06-16-2022, 08:03 PM | #244 | |
I used to do this process EVERY time I went to the track. BUT I am currently running the same settings for daily driving as I do for TRACK. The IMPORTANT thing is that you set up your toe-in toe out setting to be almost neutral. This is what will prevent premature tire wear. I CURRENTLY run -3.7 camber on front and -2.7 camber on rear (have to use SPL TOE RODS to get this much rear camber). NOTE: I am running MORE aggressive camber settings than what I originally did when the alignment below was done.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 06-16-2022 at 09:57 PM. |
06-23-2022, 03:52 PM | #245 |
Thanks for the info. I did find out if you quickly disconnect the sway bar links it loosens the strut assembly considerably, allowing for ease of movement.
04-10-2023, 05:24 PM | #246 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
Resurrecting this thread; what is the point of getting camber plates if you can already get -3.3° camber in the front? Assuming you don’t want even more negative camber and you are willing to drive on the street with track settings…
Are there any other advantages? Does it hold and keep the alignment more stable and consistent for longer? Does it save the alignment shop time and therefore money for every alignment? Or does it have something to do with toe and castor settings being compromised as a result of the high negative camber? I currently have -3.3° camber in the front of my ZL1 without camber plates, I am happy to get them if there is a good reason but did not want to waste $1000 Canadian
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
04-10-2023, 05:40 PM | #247 |
i have most of my camber in the bottom and some of it in the top not sure why they did it that way but it works for me lol
04-10-2023, 05:52 PM | #248 | |
Does your front end alignemnt stay more stable and consistent for longer?
04-10-2023, 06:11 PM | #249 |
yup i have full spl parts mcs coilovers and vorshlag camber plates about 5-6 track days a year and only have to go to alignement shop once a year or so to get a checkup
04-10-2023, 06:56 PM | #250 |
But specifically, did your front end alignment start to become more stable and consistent for longer after you added the Camber plates in particular?
04-10-2023, 07:39 PM | #251 |
[QUOTE=GunMetalGrey;11304368]So what improvement or benefit did they give you over and above your already -3 camber before you had the plates installed?
Does your front end alignemnt stay more stable and consistent for longer?[ /Slicks like all the camber you can throw at them especially when you have heavier cars like ours. The turning response is quicker at 3.9 camber vs 3.3 camber. The car also transitions faster It may actually be more noticeable on a ZL1 due to the heavier nose weight vs an SS 1LE Sent from my iPhone
04-10-2023, 08:23 PM | #252 | |
[QUOTE=sr71bb;11304411]
Does anyone know how much caster is too much caster? I know that when I get up to -3.3 camber without camber plates, the caster starts going up as well… I assume that with camber plates the caster can be made to stay where it was stock OEM if desired. I’d also still like to know if camber plates help hold the alignment stable and consistent for longer than without.
