Old 05-13-2017, 04:10 PM   #1
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
When installing springs, do you loosen ALL bolts to clock bushings?
I've been looking at a few pretty good YouTube videos from Phastek on installing lowering springs and in the rear they only mention loosening the trailing arm, lower control arm, and whatever the lower front arm is called. That leaves a couple of items (the upper control arm and toe rod) that don't need to be loosened to have to install the springs. Did you loosen these anyway when clocking the bushings or is it only the items the videos tell you to losten?
I have everything out and the car up in stands an am just waiting for the springs to arrive on Tuesday to install. Thanks.
As a side note, on my car it was impossible to remove the lower control arm bolt on both sides without mangling the sheath on ABS sensor...
Eric SS is offline   Reply With Quote
Old 05-13-2017, 09:39 PM   #2
LSmith353
LSmith353's Avatar
Drives: 2015 Ultimate Track SS
If they are not loosened during disassembly, then there is no need to re-clock them. They should still be "clocked" because their position relative to ride height does not change. Only components on the lower side will be re-oriented.
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/
2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD
2010 2SS/RS M6 -- SOLD
LSmith353 is offline   Reply With Quote
Old 05-13-2017, 10:39 PM   #3
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
I think that is the Parking brake cable you are talking about.
Mine got a little scrapped up as well.
It is the rubber bushings that you need to be aware of.
Make sure that the suspension is loaded before you torque everything up.
Don't have the wheels hanging free when you torque. Use a jack to lift the wheels & suspension up before you torque.
My issue was not torquing to spec. Lying on the garage floor makes it hard to hit the 80+ft/lbs. My lower shock bolt was loose and I had a clunking noise because of it.
Old 05-13-2017, 10:56 PM   #4
irmb
Drives: Camaro SS
Yah, the Phastek video makes that look easy to get out of the way. It's not. Hopefully you put it back in reversed so next time is easier.
irmb is offline   Reply With Quote
Old 05-14-2017, 04:04 PM   #5
Eric SS
#becauseracecar
Eric SS's Avatar
Ok thanks. I went ahead and loosened everything up just in case.
Old 05-14-2017, 04:05 PM   #6
Eric SS
#becauseracecar
Eric SS's Avatar
Yeah, now that you mention it it is the parking brake. I'll defiiitly have the suspension loaded and the jack under the brake was the plan
Are all the suspension components 80 ft/lbs back there?
Old 05-14-2017, 04:06 PM   #7
Eric SS
#becauseracecar
Eric SS's Avatar
The springs don't arrive until Tuesday but the plan is to definitely put those bolts in the other way!
Old 06-11-2022, 09:20 PM   #8
JDaniels609
JDaniels609's Avatar
Drives: ‘22 2ss
Instead of starting a new one guess I’ll try and bring this back from the dead. Along with absolutely shredding my ebrake cable I’m also curious if I need to clock the bushings on the upper control arms and toe arms… can anyone help me out? Part of the way through installing bmr springs
‘22 2SS A10
JDaniels609 is offline   Reply With Quote
Old 06-13-2022, 09:11 AM   #9
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
The toe link on V8 cars uses a pillow ball bushing and should not need to be "reclocked." On V6 and L4 cars it's rubber and should be reclocked. I think the upper lateral link uses rubber bushings, but I'm not positive. If so, it should also be reclocked.
In response to post #2, the reason you would want to reclock all these rubber bushings is that (presumably) the new springs are lower and therefore the rubber would be torsion at static ride height if you skip this step. If the car doesn't change ride height and you didn't loosen the bolts, then you would not need to reclock the bushings during reassembly.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
