09-13-2013, 08:18 AM | #1 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
SCT capable of logging multiple vehicles?
Wanted to log another vehicle. But livelink fails when trying to communicate. Is it possible to log other vehicles or is the SCT just able to log one vehicle? Would I have to unmarry the SCT? If so, I believe that it can only be done a number of times, think 5. The other vehicle is an 01 Escape with P1132, 1152, 0172, 0175. Codes are for both upstream O2s and both banks rich. Was hoping to view a few things and narrow down the problem(s).
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
09-13-2013, 08:29 AM | #2 | |
Drives: 2010 Camaro Join Date: Feb 2010
09-14-2013, 06:22 PM | #3 |
GrINned & JUICEd
The livelink 2 shows the option for ford and gm, so idk. Followed the steps and failed. Don't know if the hand held is locked to the camaro vin, thus causing the issue of communication failure.
09-14-2013, 06:28 PM | #4 | |
As for using the livelink.... Got me. I only log the camaro. |
09-15-2013, 11:48 AM | #5 | |
You will need a Ford Unit to Log a Supported Ford Product. Ted.
www.jannettyracing.com
09-15-2013, 12:48 PM | #6 | |
Drives: 2SS/RS Join Date: Sep 2008
It is because you are trying to use it on a Ford. The vin locking only applies to tuning. All the other functions such as logging and code reading will work on other vehicles as long as they are from the same manufacturer. |
09-15-2013, 12:48 PM | #7 |
GrINned & JUICEd
Gotcha, that explains it. Thanks.
