04-12-2012, 09:16 AM | #1 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
SCT Units
I'm changing the units, such as fuel pressure from kpa to psi. I save the configuration on the PIDs selection screen and continue to "Configure Datalog" (small box bottom right corner). In the PIDs logging table, the unit is PSI. OK great. Now if I load the config file I just saved, my PIDs return, but there is nothing in the the units column of the table. When I select "List" (3rd ribbon box on top) I go back to the PIDs screen and the units column has kpa. WTH. What am I doing wrong?!
Also, when I load any config file, the units column is blank on the data logging table. Too much time pi$$'n with this. Oh ya, failed to mention. SCT forum restrictd for SCT Dealers and/or SCT Pro Racers only. Huh.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
04-12-2012, 03:35 PM | #2 | |
Use this chart to convert.
www.jannettyracing.com
04-12-2012, 04:30 PM | #3 |
GrINned & JUICEd
It was my belief that the LiveLink software would do the conversion, since the unit of measure could be selected. Thanks for the table.
04-12-2012, 08:12 PM | #4 | |
SCT FTW. Ted.
04-13-2012, 08:02 AM | #5 |
GrINned & JUICEd
Ya, it's really easy to navigate. I spoke with SCT tech support. The tech talked with one of their software engineers. They did not dismis that the software could not convert the units. They did say there were bug issues with the new software. So I'm hoping. I need to email SCT some info and files. So I'll wait and see what happens afterwards.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Official INFERNO ORANGE METALLIC (IOM) Camaro Thread | Tran | Camaro Photos | Spyshots | Video | Media Gallery | 3819 | 02-25-2024 01:45 PM |
COLOR Question? | skipinminn | 5th Gen Camaro SS LS LT General Discussions | 26 | 03-13-2012 11:04 PM |
2010 Camaro color and model popularity as of Mar 06, 2010 (from spasticsquirrel) | TAP101 | 5th Gen Camaro SS LS LT General Discussions | 47 | 08-01-2011 05:17 PM |
2010 Camaro color and model popularity as of Jan 16, 2010 (from spasticsquirrel) | TAP101 | 5th Gen Camaro SS LS LT General Discussions | 82 | 03-01-2010 07:01 PM |
GM keeping good numbers? | bballr4567 | 5th Gen Camaro SS LS LT General Discussions | 10 | 05-10-2009 10:38 AM |
