03-21-2012, 01:38 AM | #1 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
6800 miles 1st diff oil change
Decided to change diff gear oil this past weekend since the weather was great and I could do it outside, just incase I made a mess.
6800 miles, approx 20 quarter mile runs, driven moderately aggressive the majority of the time and only taken out in good weather. No mods. -------------------- Captured about 3/4 of quart as it first came out of the drain plug. This is what settled after about 2 hrs. I was surprised the axle lube was only warm after driving 40 miles. -------------------- This is the amount of material captured by the bottom drain plug. Note, there is a smear on the paper towel behind my finger, so it appears the build up sticks out further than it actually does. It had the consistency of aluminum anti-seize. I doubt the bottom drain plug could hold onto any more material. The top fill plug also has a magnet. It retained about 1/4 the amount of material that was on the bottom plug. Both plugs have a "rubber" gasket. -------------------- The new fluids, nice and clear. Bought GM stuff. My belief is that the clutches in the lsd were designed for use with a certain type of lubricant. Similar to some wet clutches in motorcycles which state not to use synthetics, if used, it could allow the clutches to slip. From what I've read, GM uses a group 3 synthetics and Mobil 1, for instance, uses a group 5. Group 5 providing better lubrication, less friction. Btw, the small clear bottle with the white lid is my brake fluid. It was syphoned out with a turkey baster. --------------------- Bought this bottle adapter/filler to transfer the oil into the diff. Got it from the local parts store. Nothing wrong with the filler, just not a good application for the diff. No room. Possibly cutting the capped end of the tube off to allow the tube to go into fill hole deeper may have helped. 2.5 oz of lsd additive per 32 oz of axle lube. I used slightly over 2.0 oz of additive and the complete bottle of axle lube.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
03-21-2012, 12:27 PM | #2 |
Nice write-up.
So is it possible that using a Group 3 axle lube with 2.5oz of lubricant additive gets it in the neighborhood of say a Group 5 lube? I'm planning on doing this myself soon. I went and bought the Mobil 1 axle lube, and picked up the little bottle of lube additive from the dealership. The problem is I still find conflicting details about using different gear oils in the Camaro's LSD. AFAIK, no one has reported any problems or slipping between using brands such as RP, Amsoil, Mobil 1, or OEM. I'm thinking mine could benefit from a lower friction formula as the diff makes rubbing noises when rolling slow with the vehicle turned sharply, like pulling out of the driveway. The owner's manual states simply to use a 75W-90 LS gear oil, but doesn't caution against group # synths or anything. Is it possible we (I mean like myself, not you Badbubba) are simply over-thinking some of the details a bit?
03-22-2012, 12:16 AM | #3 | |
GrINned & JUICEd
http://www.redlineoil.com/product.aspx?pid=41&pcid=4 states add their lsd additive 1 oz at a time until no more chatter. So if replacing with Mobile 1 and adding 2.5 oz of additive is suggested, is this correct for the best performing lsd? Seems to me, if Mobil 1 is a better friction fighter and adding the same amount of lsd additive, then the clutches may slip, which may cause more heat as well. Plus the clutches are already soaked with GM lube, so things could change in the future. We've tested a few lubricants at work for compatability, mainly greases and their bases (urea, esters, soaps, lithium, moly, paraffin) , and the result was not desirable. GM stuff will cost about $40 more, rip off imo. Just my thoughts. Yea, I over think everything.
03-25-2012, 07:19 PM | #4 |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
What is the total cost of the G M gear oil & additive?
Why not just clean the magnetic plug and put it back in?
2010 Camaro Auto, Inferno Orange, Titanium Interior, Gearhead Wheels AIRAID CAI
03-25-2012, 07:29 PM | #5 |
Drives: 4 wheels Join Date: Oct 2011
Little more metal than I would like to see in my diff
03-26-2012, 12:38 AM | #6 | |
GrINned & JUICEd
If you decide to clean the drain plug magnet, you end up draining the lube out anyway. I can never get all the debris out of my oil catch pan, small rocks, sand, rust, etc. This would contaminate the gear lube. Then the issue of getting the lube back into the diff. Also, the magnet will not attract any non-ferrous material in the lube. In hindsight, I should have placed a magnet in the gear oil that settled in the cut off 2 liter bottle.
03-26-2012, 11:46 AM | #7 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
FYI... I ran both my old trans and diff fluid through paint strainers and did not find one bit of metal in it
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
03-26-2012, 06:32 PM | #8 | |
03-26-2012, 11:20 PM | #9 |
GrINned & JUICEd
I'm not sure at what micron level a paint strainer filters. It does allow metal flaked paint to pass through it. I don't believe anyone would want metal flake in their gear lube. But at least you have piece of mind, bigger chunks, big problems.
03-26-2012, 11:24 PM | #10 |
GrINned & JUICEd
I am interested in Amsoil for the manual trans. fluid change. PM sent.
03-27-2012, 12:55 AM | #11 |
I have an appointment with my camaro to put on my solos HF cats and I asked them about changing the rear diff after break in. I have under 1570 miles on mine and they said it is not GM recommended. So should this get done now after my break in or is it a waste of money and I should drive it a bit longer? I don't do any track races either.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
03-27-2012, 10:54 AM | #12 | |
GrINned & JUICEd
03-29-2012, 10:55 AM | #13 | |
03-29-2012, 03:55 PM | #14 |
Drives: 2011 2SS/RS ord 7-7-10 home8-24-10 Join Date: Jul 2010
For what its worth, my local dealer said GM has been putting the additive in rear diff oil for years. He mentioned a part number change that has a footnote about it. I changed mine with smething under a thousand miles. The old stuff looked terrible and there definitely WAS metal. I don't drive hard so I suspect some of that is casting leftovers, but I wanted it out with all I read here. Used Amsoil Severe Gear and the GM additive. No noises and when I let a little out at like 7500 miles just to see, oil still clean and no particles on the magnet. AMSOIL has never let me down.
As far as synthetics in GM rear diffs, my Tahoe has the Eaton system and GM expressly recommends non synthetic as well as no RTV gasket maker on the cover. It has over 100K on it now with the original bearings and seals and no issues using AMSOIL Severe Gear. I've never felt like the posi wasn't working. Even in 26 inches of snow last year it was a point and go affair to drive. |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
A Look at GM's Oil Life Monitoring System | franknbeans | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 166 | 05-23-2014 06:31 PM |
best synthetic oil to use | hollywoodjose | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 130 | 01-26-2014 08:51 AM |
How often do you change your oil | Ice Demon | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 82 | 11-15-2012 04:59 PM |
Need Mechanics Help with Oil Pressure Issue on 1999 3.8 Camaro | Solocus | 4th Generation Camaros | 8 | 05-06-2011 09:49 AM |
