10-16-2022, 08:44 PM | #43 |
Drives: 2010 Camaro 2SS LS3 6 speed IOM/IOM Join Date: Apr 2010
I’m still going on my original battery. Car was born 4/29/2010
It will sit for weeks at a time and still start fine . Longest battery I have ever had! |
10-17-2022, 08:03 AM | #44 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Living in the trunk is the best thing for a battery its away from all the engine heat which is a real battery killer.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
02-18-2023, 03:26 PM | #45 |
Silverbullet
Drives: 2010 SIM 2SS/RS LS3 Join Date: Feb 2014
Mine is also a 2010 and I still have the original battery in mine. Although, I stumbled on this thread because I had searched “best” battery for a 2010 SS Camaro. I started the car yesterday after sitting for 3 weeks, and it was a bit hesitant along with the date display being a couple days off. I think it’s slowly dying on me. She sits for 1-4 weeks at a time normally with no issues. I think 13’ish years on the original battery is pretty damn good though! 😉
Mods:
Cold Air Inductions Cold Air Intake - Window Tint (15% Ceramic) - Muffler Delete w/Stock Tips - MRR ZL1 Replica Wheels (20x10 +23 front-20x11 +43 rear) - Toyo Proxes ST III Tires (275/40/20 front-315/35/20 rear) |
02-25-2023, 11:43 AM | #46 |
Drives: 2012 Crystal Red Tintcoat 2SS/RS Join Date: Jun 2012
Just replaced the original battery on my 2012 SS I've had since June 2012. Bought a Die Hard H7 AGM, 850 CCA from Advance. Not bad for an OEM battery lasting close to 10.5 years. Maybe I get the same life from this Die Hard as from the OEM battery.
ADM cold air intake with scoop, Solo Mach XL catback exhaust, custom tune, Stainless Power LT headers, RX catch can in Crystal Red Metallic
Custom Grind Cam 222int 230exh .601"/.608 116*+4, TSP 25% UD Pulley w/ ACC Serpentine Belt, 160* Thermostat, Melling High Pressure Oil Pump,LS3 Conversion,C5R Timing Chain,Amzoil ZROD 10W30,NGK TR6 Spark Plugs, Professional Stage II Cylinder Head Porting Service (360+ CFM), Install by 510 Race Engineering 445 RWHP, 419 ft/lb tq |
02-25-2023, 01:09 PM | #47 |
Blue Ray
Drives: Camaro 2SS 1LE, Blue Ray Join Date: Dec 2021
Your fortunate that you had some advance notice on the battery.
My 2014 OEM battery failed last December just all of a sudden during a cold snap. I have had good luck with Advance Auto Parts and a DieHard. It was relatively to easy replace in the trunk well. Good Luck ! |
04-09-2023, 07:57 PM | #48 |
Still going on my original battery . Car was born 4/29/10.
Any one else ? |
04-18-2023, 01:00 PM | #49 |
keep them on battery tender when not driving and the battery life will continue.
David Vianu
2010 Synergy Green 1LT |
04-18-2023, 02:43 PM | #50 |
Drives: 2014 2SS/RS Join Date: Jan 2014
Finally replaced my battery last week. Got the car in Feb of 2014, so a little over 9 years on the original. I was getting worried about being stranded, so I figured to be safe, not sorry.
I did notice the following tho... On the old battery, it always seemed to be between 14 and 15 volts on the voltmeter gauge and DIC, so matter how many miles I drove after starting it. On the new battery, immediately after starting, the voltmeter (gauge as well as DIC display) will read around 14.5 V. After driving for a block or so, the volts go down to 12.5 - 12.6 and never move above or below those two numbers. Pretty rock steady reading. Makes me think the old battery was pretty much always needing more than 14 volts to keep it happy. It never let me down over the 9+ years tho. The engine cranks the same with the new battery as it did with the old. Not sure if this is telling me anything or not!
06-07-2023, 09:39 AM | #51 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
Btw.From which model year -> the battery change must be coded ?
