Old 11-08-2022, 07:11 AM   #1
JSenek
Drives: 2020 Camaro SS 1LE
C7 Brake Components
I'm changing vehicles from a C7 to an SS 1LE. The C7 was running Z06 rotors and calipers up front.
Am I correct to understand the SS1LE uses the same rotor size and pad shape as the C7 Z06? What about bolt pattern?
I've got a set of Girodiscs I'd love to swap over, but I wasn't sure if I could, or if I'd have to swap to different hats. I've also got oem Z06 front and rear discs that would be nice to reuse if possible.
JSenek is offline   Reply With Quote
Old 11-08-2022, 01:14 PM   #2
Briland_1LE
Briland_1LE's Avatar
ask in the 1LE forum
Briland_1LE is offline   Reply With Quote
Old 11-08-2022, 01:54 PM   #3
JSenek
To anyone who comes across this in the future-
I spoke with the folks at KNS Brakes and they informed me that it is not a direct swap if you have the Girodisc hats, and it's basically impossible to get just hats from Girodisc.
If I understood correctly, if you used OEM hats, then you could transfer the rings over with a bolt kit.
