02-15-2010, 08:02 PM | #1 |
1000 watt rms
i am going to run a sub with 1000 rms. Do i need to upgrade my battery,etc? i will have a ss/rs so idk if the hids will kill the battery along with the sub. i dont mind the lights dimming and the voltage dropping a little after pounding a couple songs all out.
02-15-2010, 08:09 PM | #2 |
Derrick
i would atleast recommend a capacitor to put inline with the amp. i dont have one yet and when i start crankin on the volume the lights do start pulsating, and mine is only a 450rms amp!
2010 ABM 2SS/RS, A6, home Dec 10th, wifes birthday present! 2007 GMC Yukon XL, 2000 S10 Xtreme, 1969 Chevelle |
02-15-2010, 08:11 PM | #3 |
BAQNBLK
Drives: 2010 SS/RS BLACK W/INFERNO PKG Join Date: May 2009
Is the sub rated @ 1000 watts RMS? Or is the amplifier that you are using pushing that out continuous? Either way, if you have that type of speaker or amplifier and it is capable of handling or delivering that kind of "true clean power" than by all means, you will definitely need to run a secondary battery w/@ least a 4 ga. power cable and probably some type of capacitor set up. Oh, and by the way, the sub and amp set-up w/ any type of quality should be costing you around $2,000.00 or better. You get what you pay for. Don't forget to use Dynamat!!
02-15-2010, 08:12 PM | #4 |
what sub is it? and what amp are you planning on going with?
Also capacitor will not stop light dimming but light dimming is not a problem but factory computers start shutting off at 9vdc so if you system drops your battery that low your factory computers will be effected. |
02-15-2010, 08:41 PM | #5 |
i will be running a13w7 and a 1000v2 jl slash. How about just a battery. dont plan on pounding loud alot. just good enough so i can here it. the sub is overkill but i already bought it and dont want to sell it.
02-15-2010, 08:44 PM | #6 |
how many amps is the stock ss alternator?
02-15-2010, 08:52 PM | #7 |
battery, cap, or high output alternator..don't need to fork out all that cash for a system, unless you can afford it, or you've done your homework and know what's reputable..
02-15-2010, 10:20 PM | #8 |
stock alternator is 130 amp max,
And there is no such thing as just making a w7 a little loud, they are insanely loud, and max a 1000/1 will pull 100 amps of current, personally if it was my system I would run 2 batteries because that amp pulls massive current. |
02-16-2010, 11:19 AM | #9 |
m buyin a kinetic 1400 good to 1000 rms. the sub shouldn be loud becauze i will have a bass nob. you think i can get by with a battery i have done my hw just wonderin bout the power if it will be an issue or not. thanks i found tue battery but no dimmnsion i will need to buy a mountin braket. how hard swill it be to mount in the trunk is the floor plastic
02-16-2010, 01:13 PM | #10 | |
More human than human
you can't "hear" the stock system ?
1100 - 10/22/2008 3000 - 05/27/2009 3300 - 06/06/2009 3800 - 06/29/2009 4B00 - 06/29/2009 Warehouse 13 survivor Blood stains,speed kills,fast cars,cheap thrills,rich women,fine wine,i lost my sense i lost control i lost my mind. |
02-16-2010, 01:29 PM | #11 |
Thread Killer
check the fuses on the amp
That is the key to the trickery used on power ratings. You can find name brand 1800watt amps that have only 2, 20 amp fuses, which means it pulls less them 40amps at peak. --- Now modern cars with all its electro gagets suck down the juice and most stock system are near the max. Id atleast install a cap for when it hits hard. |
02-16-2010, 02:37 PM | #12 |
the anp does 1000 watts from 1.5 to 4 ohms i believe. i like bass and i always wanted a w7 i dont even have the car yet lol but im putting it in asap
02-16-2010, 02:44 PM | #13 |
Thread Killer
watts n ohms means jack, how many amps does it draw is what you need to know. and looking at the fuses will tell you that. As it will use less then it fused for.
02-16-2010, 03:00 PM | #14 |
so research the amp and see how many amps the amp uses. lol
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
2007 Suzuki GSXR 1000 with 3800 miles | mdinferno | Members Classifieds - Non-Automotive | 3 | 01-27-2010 09:13 PM |
1000 Mile Oil Change??? | B - GodZ | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 13 | 10-23-2009 09:50 PM |
Hot Dog, bye bye 1000 | Scott@Bjorn3D | Off-topic Discussions | 5 | 05-31-2009 01:01 AM |
1000 Members Strong! Welcome to Eleven11. | TAG UR IT | Off-topic Discussions | 14 | 07-10-2007 10:27 PM |
