10-05-2020, 07:04 AM | #1 |
Drives: 2019 ZL1 (Ordered) Join Date: Jan 2019
Took the Zl1 1/8 mile Racing yesterday
Hey Guys, took the Z to the local 1/8 mile strip yesterday, managed to get in 13 passes! Best pass of the day was a 7.26@101 with a 1.73 60ft. The car was pretty consistent with 9 passes in the 7.2x range.
My car is still 100% bone stock, right down to the factory Goodyear’s. What are some of your guys 1/8 times?? Also, what do you recommend to get this car in the 6.6-6.7 range?
2019 ZL1 Mosaic BLK 10spd
2014 GMC Sierra All Terrain 6.2L 2004 SVT Cobra - Port Blower - Pullied - Exhaust - Sold 2000 Camaro SS - 418ci LS - Brian Tooley H/C/I Last edited by NewfieZ; 10-13-2020 at 07:28 AM. Reason: Spelling error |
10-05-2020, 08:30 AM | #2 |
Drives: ZL1 1LE M6, Pontiac TransAm 400-T10 Join Date: Aug 2019
Nice to see that you had a good day, eh?
In my area, all of the tracks are closed until 2021 due to Corona. Maybe I should take off to the Great White North?! |
10-05-2020, 08:49 AM | #3 |
Drives: 2018 ZLE Join Date: Mar 2020
Great job that’s quick! If you have e85 near by you could gain that easily by adding a flex fuel sensor, an intake and a tune. My car saw about 75whp and 80ftlbs at the tires just from adding the flex fuel tuning. You will most likely need some better drag tires with the added power though also . I can run up to 60% ethanol without any issue, here are the before and after results from my dragy 100-200 (62-124mph measurement)
10-05-2020, 09:18 PM | #4 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
Great times! My best is 7.33 @ 101. 60' was 1.73 but I was running R88R's
10-06-2020, 01:22 PM | #5 |
Drives: 2017 ZL1 Join Date: Aug 2009
Those are very quick times for a stock ZL1. I think it works out to somewhere in the 11.teens in the quarter. What were the weather conditions like?
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY https://youtu.be/Lcu41obbTf8 '13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight. http://youtu.be/yggIA3C_kkA 2014... back to stock http://youtu.be/spQLaTWbThs 2013... stock & RotoFab |
10-12-2020, 03:37 PM | #6 |
Drives: 2019 Shadow Gray Metallic ZL1 Join Date: Jan 2019
Looks like the weather was in the mid 40's
10-12-2020, 08:07 PM | #7 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Nice passes! 100% stock, most of mine are in the same ballpark as yours. 7.2s between 101 and 102 mph. I've had a few 7.1s with a good track and good air. Managed three or four 7.0s with my rear drag radials with one of those at 103 mph, which lead to a 10.86 1/4.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
