03-31-2020, 11:09 AM | #1 |
Drives: '18 2SS/EU (+Recaros) M6 Red Hot Join Date: Nov 2018
More aggressive gearing
Are there any options out there for changing the gearing or final drive on the M6 SS to make the gears a little shorter?
Is the final drive of the SS and the SS 1LE identical? |
03-31-2020, 11:11 AM | #2 |
Drives: '16 2SS M6 Join Date: Aug 2019
I don't think there are any gear options for the 6th gen.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
03-31-2020, 11:14 AM | #3 | |
I believe the rear gear ratio for the SS and SS 1LE is the same: 3.73
03-31-2020, 11:18 AM | #4 |
Sure, but it takes a 6k geforce 9" swap to do it...then you will have lots of gear options.
2016 NFG 1SS A8
03-31-2020, 11:24 AM | #5 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Maybe consider going to a shorter wheel/tire combo to effectively get you the more aggressive / shorter gearing. It doesn't appear to be cost effective otherwise.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
03-31-2020, 11:27 AM | #6 | |
They must have had a price increase. $7100-$7500 now.
David
03-31-2020, 11:30 AM | #7 |
Drives: 2018 Camaro SS HW Edition, 2020 LT1 Join Date: Jan 2017
Has anyone swapped the rear gears out of a 6 speed car into an automatic car and got rid of the 2.77 gears? I know back in the 80's 5.7 Iroc's could be had with 2.77 or 3.23 gears and those cars were night and day differences in relation to performance.
1987 Camaro IROC-Z 6.0 LS 4L80
1988 Camaro IROC-Z TPI 5-Speed 1992 Camaro B4C 5.7 TPI 2018 Camaro SS Hot Wheels Edition #838 |
03-31-2020, 11:32 AM | #8 |
Sweet IROC-Z collection... let's see some pics
03-31-2020, 11:48 AM | #9 |
Snowblind did this with his NA 9 second A8 SS a long time ago. Not sure he is still running this.
No one is running now anyway. :( I am so wondering what my stock M6 LT1 will do with tires. Are high 11s possible? My Dragstars sit waiting for the falll........
03-31-2020, 12:23 PM | #10 | ||
2016 NFG 1SS A8
04-01-2020, 07:27 AM | #11 |
Drives: 2021 300 Join Date: Jan 2015
Plus reprogramming the ECM
04-01-2020, 11:11 AM | #12 | |
Drives: 2016 Camaro LT1 RS Black on Black Join Date: Apr 2017
I have a 16 RS automatic. About 2 years ago I picked up a 2017 2.0T manual dif and axles from a salvage yard in LA ($700). The Manual 2.0 has a 3.23 gear ratio as well as a limited-slip diff. I can also tell you the 2.0 axles are WAY beefier than the v6 stocks were. It's a direct swap and I did a Trifecta tune at the same time having them adjust for the ratio change. Night and day difference. I have a throttle controller in the car which was a god patch to the low-end throttle hole but nothing like this gear change did. Like a duck to water, the v6 was born for this swap. Thinking there would be a trade I was happy to find I lost no top end with that A8, just all low end all day and all at 19mpg.
NowAChevyGuy 2016 RS - Trifecta Tuned, 3.23 diff swap, Borla S Type, JMS Throttle Controller, Lambo doors, Monster stereo, GM LED rear tail lights, BMR swaybars/End Links/Trailing Arms, tinted dark and murdered out.[/br] Car kicks ass! $20k.. and I get 20mpg with my foot in it, everywhere I go!.... Say somethin about V6's now... |
04-01-2020, 02:01 PM | #13 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Answers are in the "Transmissions" technical section.
04-02-2020, 04:43 AM | #14 |
I'd like to thank everyone for all the fast and good replies. It sounds to me like I'm not the only one who thinks the gearing ratio for the 6-speed manual is a little on the tall side.
I was hoping it was possible to change out the diff gears, as that would probably be the cheapest option. Too bad they are not replaceable. |
