dave@hennessey
Old 04-15-2019, 07:43 AM   #1
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
Bad idle after track day
So Saturday I went to the dragstrip to get some test passes. I got there late so I had to run two back to back before the elimination round. Car ran great both times
They were doing bracket racing which I wasn't interested in I just wanted a go time slip so I decided I was not going to try to stay under my index. During the third pass I felt a vibration thru the steering wheel so I let off the gas and went back to the pits. Everything seemed ok so I thought it was maybe a tire balance issue. Drove home everything normal no codes. Yesterday I started it and there was a definite miss but no codes. Tonight I'll pull the plugs and try to see what's going on. It's a 2013 ss auto with 34000 miles headers intake 3.91 gears. Should I expect the worst?
StingrayblueSS is offline   Reply With Quote
Old 04-15-2019, 08:04 AM   #2
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Change the plugs maybe. Did you change them when you installed headers? If you dropped one or bumped one with a header they crack rather easy and can cause a good miss over time.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 04-15-2019, 08:16 AM   #3
StingrayblueSS
That's what I'm hoping for something simple. Engine sounds the same with no loud tick or anything.
Old 04-15-2019, 12:19 PM   #4
StingrayblueSS
I didn't change the plugs or remove them. the headers have been on for two years.
Old 04-15-2019, 12:36 PM   #5
HyperV117
HyperV117's Avatar
Drives: 2010 Camaro 1SS
Bad idle can be a bunch of things. I was dealing with this recently. I cleaned the MAF, the throttle body and did the fuse pull and that made a huge difference and not only at idle. A few days later I had a really bad misfire but then I found that one of the ignition cables had come off the coil.
Finally there's fuel. If for some reason you got some bad fuel in the tank it's possible the car isn't going to go back to normal until you replace that batch. Doing the fuse pull after that should clear it up.
HyperV117 is offline   Reply With Quote
Old 04-15-2019, 03:56 PM   #6
StingrayblueSS
Here's the left bank plugs
Old 04-15-2019, 04:46 PM   #7
StingrayblueSS
Here's the passengers side. Also found loose wire that may have caused the misfire.
Old 04-15-2019, 05:40 PM   #8
StingrayblueSS
Input would be appreciated on condition of plugs to me it looks like the electrodes are almost gone.
Old 04-15-2019, 05:54 PM   #9
StingrayblueSS
Input on condition of plugs would be appreciated. Looks like the electrodes are almost gone.
Old 04-15-2019, 06:06 PM   #10
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
hard to tell but some look like they are pretty worn.
JD555 is offline   Reply With Quote
Old 04-15-2019, 06:52 PM   #11
StingrayblueSS
Only 34000 miles
Old 04-15-2019, 06:52 PM   #12
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Plugs look OK, that one plug wire looks a little crusty.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 04-15-2019, 07:04 PM   #13
StingrayblueSS
That's the wire that was loose from the coil.
Old 04-15-2019, 07:53 PM   #14
zz430camaro
Drives: 2015 1LE
Did you swap it out and see if its OK?
