09-16-2021, 12:34 PM | #15 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Thats good to know, I did a mod on my stock air box 6 months ago and have been running the stock filter.
09-16-2021, 12:36 PM | #16 |
The Wicked Jester
Drives: 2020 Camaro 2SS Orange Crush Vert Join Date: Sep 2012
I know that everyone has an opinion regarding the multiple intakes. I has a CAI on my 2014. My 2020 came with a factory GM but really similar looking CAI - I was going to do this anyway so it was good from the factory.
As far as performance - not sure if there is any - BUT I do like the way this looks over the stock intake - so - the choice is yours...but I do go for the nicer look...if only I could find an orange filter I would be set in regards to the color combo... lol
New Car (His): 2020 Camaro Orange Crush Convertible 2SS
New Car (Hers): 2020 Camaro Satin Steel Metallic Convertible 2LT/RS Redline Package Old Car: 2014 Camaro Summit White 2SS/RS Old Car: 2010 Camaro Inferno Orange 2LT/RS |
09-16-2021, 05:56 PM | #17 | |
As far as doing the cut airbox, we did have a member track test a cut airbox with green filter vs a Rotofab CAI on an SS quite a while ago, and the Rotofab won on that day. |
09-16-2021, 06:14 PM | #18 |
Drives: like an old lady Join Date: Jun 2012
you will find different answers for both sides on any mod worth <10 hp. after a couple years of ownership a washable filter would pay for itself if nothing else.
my anecdotal evidence: when my car was stock (untouched everything, except green filter) i never got beat by another stock camaro. i raced several. car? driver? green filter added 75 hp? your guess is as good as mine.
09-16-2021, 06:27 PM | #19 | |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
09-16-2021, 06:33 PM | #20 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
But what about the filtering efficiency? In reality you could probably drive a modern vehicle for probably most of life with no filter at all and be fine. However, if you were driving it in the desert sandstorm for all its life it probably would not last too long. The OEM durability and filtering efficiency standards are insane, you can take the OEM paper filter apart and roll out the pleats and it would stretch 100s of feet.
09-16-2021, 07:50 PM | #21 | |
09-17-2021, 09:12 AM | #22 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
I like Green filters or K/N purely for the efficiency of not replacing them every year. Other than that, I don't know how much utility they actually provide. If you do make the move, I would do it when your current air filter is up for replacement.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
09-17-2021, 09:51 AM | #23 |
09-17-2021, 10:45 AM | #24 | |
If you open up a filter, you lower restriction. This will only have an impact at high volume/velocity airflow. There is a cost in that you will lose filtering efficiency at low rpm. And if you clean it often (as in a washable filter) you are also removing the "dirt plug" which actually increases filtration efficiency. I'm not into the performance filters/CAI stuff. But this appeals to the same crowd that changes oil every 3000 miles, so they're probably OK. |
09-18-2021, 12:15 AM | #25 |
Drives: 2016 SS Join Date: Jan 2016
maybe gain some horsepower now with the cotton filters, scratch up your cylinder wall and lose some horsepower later, pick your poison, or stick with OEM
https://www.nicoclub.com/archives/kn-vs-oem-filter.html |
09-18-2021, 10:07 AM | #26 |
________/\_
09-18-2021, 04:13 PM | #27 |
AEM Filter, is a fantastic air filter and it never needs to be oil where you don't have to worry about ruining your mass air flow sensor.
09-18-2021, 07:38 PM | #28 |
Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
Not an air filter but you could add a velossa air scoop to your setup.
