Old 08-01-2021, 10:15 PM   #1
Flash2.0
Drives: Chevy Camaro
Weight Reduction
I Daily Drive My 2017 SS Cam,Heads, and Hi ram what all can I take out and off the car to cut weight. Already have seat delete wit a race seat. HELPPP
Flash2.0 is offline   Reply With Quote
Old 08-02-2021, 12:53 AM   #2
Village Idiot
Drives: 2019 Camaro SS
Stock suitcase, lighter wheels, a/c, windshield washer reservoir, CF driveshaft, seats, catless headers, put yourself on a diet
Village Idiot is offline   Reply With Quote
Old 08-02-2021, 12:58 AM   #3
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Seats are the heaviest bits. Then carpets and all plastic and fiber panels throughout. Then wheels and brakes.
Watch the COPO build video and do what they do, if you are serious about bigtime weight reduction. But that's probably beyond what most would be willing to do with a daily driver.
Old 08-02-2021, 07:46 AM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
Where can I find this video?
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 08-02-2021, 11:49 AM   #5
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
just did the antigravity battery that took off over 30lbs ! and rear seat delete and race seat
https://www.camaro6.com/forums/showt...ht=antigravity
Old 08-02-2021, 12:14 PM   #6
Rayvan
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic
Keep in mind, any weight-saving by removing the suitcase muffler, would likely be offset by the rear bumper, which inadvertently becomes a parachute at higher speeds without it.
Rayvan is offline   Reply With Quote
Old 08-02-2021, 12:14 PM   #7
FarmerFran
FarmerFran's Avatar
I was like hey, 40lbs my fatass car could use a diet. $950 my car will continue to be a fatass
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top.
Old 08-02-2021, 12:27 PM   #8
kropscamaro16
haha i lost 60lbs a few years ago best weight reduction i ever had
Old 08-02-2021, 02:33 PM   #9
LT1ornothing
Drives: 2020 LT1 M6
Originally Posted by Rayvan View Post
Keep in mind, any weight-gain by removing the suitcase muffler, would likely be offset by the rear bumper, which inadvertently becomes a parachute at higher speeds without it.
What exactly do you consider high speeds? My LT1 is not any slower after removing the factory suitcase up to 150 mph.
Old 08-02-2021, 03:38 PM   #10
Rayvan
Rayvan
That's because it's electronically limited. I just takes you longer to get there now...
Old 08-02-2021, 04:02 PM   #11
LT1ornothing
Drives: 2020 LT1 M6
It definitely does not seem that way. I have raced before and after the suitcase delete with other friends cars, digs and rolls, and the results have been identical. No one has modded either as we are all under warranty. The only way I can see the rear bumper parachute effect you described without the factory suitcase in place is if you are trying to top out the car (if the speed limiter were to be removed) or on the highly unlikely chance that I was racing to 150 mph+ speeds AND fighting a 40 mph head on wind. I can definitely see a parachuting effect without the factory suitcase in those most extreme of situations as just previously mentioned.
Old 08-02-2021, 05:35 PM   #12
Rayvan
Rayvan
On a road course, one can just follow a car without the stock muffler. At the end of the longest straights, the bumper cover starts to vibrate, and balloon a bit. That's drag. Some have even built a plate to prevent it, post removal. If you're after every bit of weight saving, and gone so far as removing small plastic interior pieces, I'd think this would make a bigger difference than that. That's all I'm saying...
Old 08-02-2021, 05:39 PM   #13
Checkmate1
Drives: Garnet Red / ZL1 1LE
Agreed! I have seen this happen at COTA and VIR. I would strongly suggest folks leave the stock suitcase mufflers on.
With regard to weight savings - I suggest lighter front seats + rear seat delete.
#SAVETHEMANUALS
Checkmate1 is offline   Reply With Quote
Old 08-02-2021, 05:55 PM   #14
LT1ornothing
Drives: 2020 LT1 M6
The plate sounds like a good idea, I don't road course, just friendly Mexico runs and the occasional 1/8th or 1/4 mile event. I was thinking of eventually throwing the factory suitcase back on when the warranty expires so I can throw some catless long tube headers on the car. Truthfully, I removed the suitcase because axlebacks and catbacks are outrageously priced for this car compared to every performance car I have had. A $100 muffler delete and a 35 lbs weight reduction was a no-brainer. For my uses, I have not experienced any adverse effects.
