02-12-2016, 08:31 AM | #15 | |
Drives: 2012 SS LS3 Join Date: Nov 2011
Its as if you even mention drag racing in the 1LE forum your gonna get your hand slapped. Some of us want a do it all car that is good at HPDE's, autocross and decent at the drag strip.
Buttonwillow 2:23.736
Sacramento Raceway 12.89 at 112 mph Thunderhill 2:22.242 |
02-12-2016, 08:36 AM | #16 |
Drives: 2004 Z06 Join Date: Jan 2016
02-12-2016, 09:48 AM | #17 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Haha, yup...I am a drag racer at heart. Since I was 17...now almost 40. But over the past few years I have been getting into autocross as well. I find both fun, just in different ways. I plan on doing both with this car as well.
02-12-2016, 09:52 AM | #18 | |
Drives: SS 6 speed of course Join Date: Jan 2016
Same deal with the Focus ST. There are overheating issues with brake based e-diffs. I race a Type R and a 2015 supercharged SI, both with true Torsen diffs. My family owns several farms and the GM e-diff in trucks is very very weak. A Eaton unit AFAIK.
02-12-2016, 10:35 AM | #19 | |
I used to be Dragoneye...
02-12-2016, 10:42 AM | #20 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
This car is going to be EPIC!!! I can't wait to get my hands on one and hit Road Atlanta, Sebring, Daytona, VIR, and The Glen!!!!
MJK3888 Instagram Link
02-12-2016, 10:51 AM | #21 | |
I loved that. |
02-12-2016, 10:54 AM | #22 | |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
02-12-2016, 11:19 AM | #23 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
I can't speak for the 1LE 6th Gens, but the C7 Corvettes do have a DIC screen for tire temperature. I assume they have a sensor that is either integrated in TPMS or an additional one in each wheel.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
02-12-2016, 10:07 PM | #24 | |
Camaro owner for 29 years
Drives: 96 Viper GTS/09 Sky Redline/95 Z28 Join Date: Jul 2008
http://driving.ca/chevrolet/corvette...t-corvette-z06 "How sophisticated is the Corvette’s Performance Traction Management system? Well it even, in a first says GM, accounts for tire temperature. Every seasoned track addict knows that, for maximum traction, tires have to be warmed up. Typically, this requires judicious throttle management and restrained driving from the often keyed up driver; more than a few have unceremoniously crashed on their “out” lap. Not with the 2015 Z06, you won’t. When the ‘Vette senses that its tires are below 45 degrees Fahrenheit, it assumes only 70% of maximum traction is available and adjusts the ABS and electronic rear locking differential to prevent tire lockup/spin. Between 45 and 115 degrees, it assumes 90% of peak grip is available and goes into standard ABS and eLSD modes. Only once the tires reach 115 degrees does PTM assume maximum traction is available, allowing progressive eLSD locking on corner exits and lenient ABS operation on corner entry. " "Chevy uses the tire temperature data available through the 2014 C7 Corvette Tire Pressure Sensors to more carefully control its ABS and electronic differential. Because the 2014 C7 Corvette Tire Pressure Sensors don't measure tire temperature directly (they actually measure the temperature of the TPMS sensor's microprocessor), it's not a perfect science, but it is one that data modeling can largely overcome. And it's one more piece of information that can be utilized to enhance the driving experience. Tire temps are split into three categories: cold (below 45 degrees), warm (45-115 degrees) and hot (above 115 degrees). In "cold" mode ABS intervenes sooner and more progressively, while the differential is more aggressive to limit inside wheelspin. As temps increase, ABS control intervenes later and becomes more lenient, while differential locking ramps up more slowly. These 2014 C7 Corvette Tire Pressure Sensors with built-in valve stem, delivers real time tire pressure information to the driver. When a tire is losing pressure, the 2014 C7 Corvette Tire Pressure Sensors provide an early warning, buying time to find a suitable place to stop. " |
02-12-2016, 10:22 PM | #25 |
#becauseracecar
Nice. So will the 1LE have this capability?
02-12-2016, 10:46 PM | #26 |
I don't think so. The car doesn't use Performance Traction Management, which is the software magic behind that dynamic ability. ...perhaps the Z models?
02-13-2016, 08:10 AM | #27 | |
Dodges all the cones
Drives: Soon Join Date: Sep 2015
--kC |
02-13-2016, 08:39 AM | #28 |
I don't know why it wouldn't be there, that is a big reason for even having the eLSD. Maybe it will be for the Zs and we haven't seen anything about it yet. GM likely would be bragging about it not hiding it.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
