03-11-2018, 08:59 PM | #1 |
Drives: 2017 Chevy Callaway Camaro ZL1 Join Date: Mar 2018
Best Audio System in a Callaway Camaro ZL1???? *Build Log Inside*
This job was a massive undertaking. A complete Musaic Audiophile Conversion combined with our custom Radar and Laser Integration. We engineered our equipment to blend into the factory DNA of the vehicles OEM design.
Starting with the audio, we completely gutted the interior and sound dampin the car with Soundskins Pro. This ensures that we will have a much quieter environment to enjoy the subtle nuances of our audio system. The front stage consists of a Focal Utopia No.7 3 way speaker set run fully active. We used a simple set of Focal Integration speakers to replace the rear speakers. The OEM interior plastic panels were also treated with Soundskins Pro to eliminate any potential panel rattle. The inner doors were treated with Blackhole Tile to greatly reduce the back wave reflection from the door speakers. Hand fabricated PVC speaker adapters were made to mount our Focal drivers right to the existing bolt holes of the OEM door skin. A Nav-TV M650-GM interface was used to take the OEM audio signal, ensuring we have a clean, unclipped, full range signal directly to our Mosconi 8to12 Aerospace DSP. An AMAS2 was added to connect our HI-Res Fiio DAP to a separate preset giving us a clean digital source directly into our processor. That signal then fed into three Mosconi ZERO amplifiers. A Mosconi ZERO1 powered two Focal Utopia 21wx Subwoofers and two Mosconi Zero4's were used to run our front 3 way Focal Utopia and rear coax fully active. The mid and tweeter of the Focal Utopia No.7 Kit was housed in a hand fabricated custom A-Pillar which was wrapped with an exact match OEM vinyl. A new Stinger AGM battery was used to replace the OEM battery and a AGM trickle charger was permanently installed next to it. A flush mount marine 120v plug was mounted under the car for an easy, hassle free, charging solution. A Stinger 10 Farad Cap was added to dampin the high voltage spikes of the factory alternator. The subwoofers were housed in a baltic birch subwoofer enclosure with an acrylic window, which gives you sight to view the beautiful magnets. The rear of the enclosure can be viewed if you pull down the rear seat. The amp rack was completely fabricated using multiple layers of acrylic and PVC. We made mostly everything by creating organic shapes using multiple router techniques and heat to bend and manipulate the materials. The materials used in the trunk were to bring focus onto what was used in the interior. Black Alcantara suede, brushed aluminum, matte black, matching black vinyl, and red and white accent lighting were used to layer the trunk. All panels are securely mounted used 1/4-20 Stainless hardware. Everything can be removed and put into the very same position as if the panels were OEM. For the Radar and Laser we used a K40 Electronics RL360i Expert utilizing a front and rear radar sensor and 4 separate laser diffusers. The front laser diffusers were fabricated to ghost into the front bumper openings. Molex plugs were used to terminate each harness going to the front and rear bumper for OEM like servicing. A static touch maser power kill switch was mounted behind the suede panel to the right of the factory radio over the Callaway emblem. Hit this once with your finger and you can easily kill power to the entire radar and laser system. |
03-11-2018, 09:00 PM | #2 |
03-11-2018, 09:00 PM | #3 |
03-11-2018, 09:19 PM | #4 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
Nice system, nice install. What...about $20k?
03-11-2018, 09:29 PM | #5 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
That's amazing. Super clean setup
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
03-11-2018, 10:40 PM | #6 |
Drives: 17 NFG ZL1 17 GTR 22 RS6 Join Date: Apr 2017
being someone that can really appreciate something like this and at the same time get offended by nice system?! nice install?! I'm completely speechless on both accounts.....lol Probably the cleanest and well thought out system I've seen in a Camaro....ever! I cant even think about the cost for something like this, but my curiosity wont let it be. PM for something like this minus the laser features (I like it, but damn sure don't need it...lol)
03-12-2018, 01:29 AM | #7 | |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
1st, every aspect of sound deadening was used correctly. CLD, CCF, MLV. It may have added 200-300 lbs to the weight of the car, but this is the right way to do it. The drivers (Focal) and amplifiers are top of the line. The attention to detail in every aspect of the build is amazing. For a custome, The is easily a $20k+ job. Most guys on this forum are more about performance than audio, but hopefully they can appreciate what a nice job you did here! Perfect
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
03-12-2018, 01:32 AM | #8 |
Drives: 17 SS 1LE Join Date: Dec 2015
I saw the YouTube video for this a few weeks ago. Let's just say I didn't want to think how much it cost.
03-12-2018, 01:44 AM | #9 |
03-12-2018, 02:30 AM | #10 |
03-12-2018, 04:58 AM | #11 | |
Here's an idea: you post all my thoughts from now on...in your words. You seem to have a lot of them. I was simply short and concise. BTW: here is the other post I submitted in the other thread by the op: "Wow. Just Wow. Looks like you lined everything but the roof." Speechless? Hardly. Last edited by JB'sZL1; 03-12-2018 at 05:09 AM. |
03-12-2018, 06:56 AM | #12 | |
03-12-2018, 07:25 AM | #13 |
Yes, here we go. If you weren't "entertaining"...why did you quote me?
Your ad hominems say it all. As the consummate audiophile (as you are someone that can appreciate), how have you upgraded your audio system? Have you even replaced a speaker, amp, soundproofing? I have done all. I'm just sayin', perhaps you could use your words and quotes more carefully. Know that I am not remotely offended by whatever you have to say here. I'm just here to learn and post my thoughts. Final thought: You ever say what you just posted about me to someone's face...in person? Or is it just on the internet the bravado comes out? |
03-12-2018, 11:38 AM | #14 | |
Tags |
audio, matt schaeffer, musaic, system, upgrade |
Thread Tools | |
