08-04-2017, 04:57 PM | #1 |
Drives: 2010 2ss camaro Join Date: Aug 2016
Car won't move...
Got on it a little in 1st went to 2nd hear a pop. Car now doesn't move. It kind of goes forward a little like tries to move but doesn't in first and reverse can leave it in gear with it stationary and nothing. No clutch smell at all, and clutch hasn't been slipping at all. Ls3 68000k . Any ideas what it could be?
08-04-2017, 05:08 PM | #2 |
Drives: T Join Date: Mar 2015
There are a lot of missing variables, did you break the diff? does the engine turn over?
08-04-2017, 05:34 PM | #3 |
Yes engine turns over and runs I have to still use clutch to put in gears and take out of gears but I can leave it in gear and with car not moving it still stays running if I step on gas even in gear with not moving it does nothing just revs. No loud mechanical sounds
08-04-2017, 07:43 PM | #4 |
Drives: 2011 Camaro ZL585 Convertible Join Date: Jul 2017
I broke a differential and rear gears in a lifted 1984 sierra a few years ago. Pretty much the same as what your describing, except with the clutch out in gear you could hear pieces of broken rear end parts moving around. Can you see if your drive shaft spins with it in gear, if I does at least you narrowed it down to something in the rear end. If not its probably something in the trans.
08-04-2017, 09:03 PM | #5 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
axle...
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
08-05-2017, 11:25 AM | #6 |
Drives: 2018 1SS M6 Join Date: Nov 2014
Are you saying the car won't move on it's own power, or won't move at all? In other words, you can't push it either?
I guess the first thing I would look at would be the drive shaft at the output shaft. If the driveshaft is broken or off. When you push on the clutch now, do you still feel a friction point? |
08-05-2017, 06:52 PM | #7 |
The car moves when towed I'm pretty sure frank is right I got to go back to shop tomorrow and check it out. When the car is in gear from a stop when I slowly disengage the clutch it attempts to go forward and backwards in reverse. It just barely moves in both directions when put in respected gear but won't move on its own. I am gonna put it on jackstands tomorrow and check out the driveshafts and half shafts (axles). I had to pull it back a 1/4 of a mile in reverse to get back to my shop and car would go faster than being towed if I gave it a little gas so I believe one of the axles is broke more than likely the passenger side but I don't know till I put it up on stands. Thank you everyone for your replies
08-05-2017, 09:19 PM | #8 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Rear end or axle issue here.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
08-06-2017, 06:04 AM | #9 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Hmmmm...I would deduce something broke.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
08-06-2017, 04:49 PM | #10 |
Any idea if cryo treating stock axles would do anything?
08-06-2017, 06:55 PM | #11 |
its time to go ZL1 if you have enough power to lay waste to SS gear.
08-06-2017, 07:58 PM | #12 |
axles break due to wheel hop...plenty of 10 sec cars on here with stock rears...
08-08-2017, 06:59 AM | #13 |
Drives: 69 SS Camaro 2019 Corvette GS Vert. Join Date: Jan 2017
It sounds like you may snapped the pinion gear in the differential or the mainshaft in the trans. Once you have the car in the air, (without it running) put the trans in 1st gear and try turning the wheels by hand. If they turn you probably snapped one of those two pieces. If you brke the driveshaft loose (not real likely), it would be banging around when you let the clutch out.
There is a fine line between hobby and obsession and I think I crossed it!!
08-12-2017, 10:28 AM | #14 |
Replaced the broken passenger side axle all is good now. Thank you everyone
