Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Exterior Parts & Accessories
Old 01-05-2016, 04:23 PM   #1
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
ALL SOLD!! GT344 Locking Gas Cap (0) GM#23159210
2010-2015. Comes as a kit you need to assemble, but the nice thing is it uses your EXISTING car key!
You code it to your key, so it goes with your car. And no separate key to fiddle with. You use your ignition key.
Sealed in the original ACDelco baggie.
GM lists these for $96.70.
UPDATE: I have NONE available. Shipped to continental U.S.- XXXX USD firm. If you can get one somewhere else for less, then buy it.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 01-06-2016, 12:58 PM   #2
ddaman922
ddaman922's Avatar
Drives: 2014 Red Hot 1SS M6
I'm sure it comes with instructions to code your key to it?
2014 Red Hot 1SS M6 aka Bernadette
ADM LSA Conversion, ADM FPCM, 2.75 pulley, ZL1 fuel pump, FAST 89lb injectors, NGK TR7IX, Roto-fab intake, Stainless Power 1 7/8" long tubes w/o cats, NPP, Elite catch can, LG G5 Coilovers, Hurst shifter, GM strut tower brace, 1LE steering wheel, MRR 228 wheels, Nitto Invo 275/315.
Tuned by Lashway Motorsports 575rwhp 528rwtq.
ddaman922 is offline   Reply With Quote
Old 01-06-2016, 01:29 PM   #3
BronxxBombers213
BronxxBombers213's Avatar
Drives: 2010 Camaro 2SS RS
yep I think mine came with a sheet.. i see it there in the photos.. there is a thread also about how to do it. I did it last year, it wasnt too bad
BronxxBombers213 is offline   Reply With Quote
Old 01-07-2016, 08:07 AM   #4
el ess A
Older Than Dirt
el ess A's Avatar
It comes with everything you need to code and assemble the lock cylinder. Tiny springs, a slew of tumblers, instructions, and all that. It doesn't use every tumbler, but which ones you use are important to get exactly flush with the cylinder while test sizing.
The major thing to remember is not to put the cylinder in the cap with the locking tumbler attached until you are POSITIVE you have the right tumblers in the right spots.
Instructions are pretty straightforward, but the DIY on here helps a lot.
Old 01-07-2016, 05:49 PM   #5
Daykell82
Drives: Camaro SS RS
Would this still work if the key is separate from the electronic fob? My keys have had the recall?
Daykell82 is offline   Reply With Quote
Old 01-07-2016, 11:34 PM   #6
cms
Drives: ZL1 Camaro
PM sent
cms is offline   Reply With Quote
Old 01-07-2016, 11:48 PM   #7
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I'll take it unless someone has already.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 01-08-2016, 01:26 AM   #8
el ess A
Older Than Dirt
el ess A's Avatar
Yes. It takes the side cut blade key. Has no bearing whether or not you had the recall performed to switch to the new type of key or already came that way.
One pending sale, that means one left. PM me if interested!
Old 01-08-2016, 01:28 AM   #9
BronxxBombers213
Yes, actually works better that way since the you have to turn this cap with the key still in there... The small opening and the full FOB make it kind of clumsy to open
Old 01-09-2016, 01:02 AM   #10
el ess A
Older Than Dirt
el ess A's Avatar
One sold and paid for. Got one left!!
Old 01-09-2016, 01:31 AM   #11
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
Oh man I might have to get one of these! Lol I hate having 2 separate keys
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 01-09-2016, 06:44 PM   #12
el-guapin
Trust No One!
el-guapin's Avatar
Drives: 2010 SIM 2LT/RS
PMed you.
el-guapin is offline   Reply With Quote
Old 01-10-2016, 12:06 AM   #13
el ess A
Older Than Dirt
el ess A's Avatar
Originally Posted by el-guapin View Post
PMed you.
PM'd you back.
Old 01-10-2016, 01:30 AM   #14
BRAVO 2SS
Aim Small...Miss Small
BRAVO 2SS's Avatar
Drives: 2018 ZL1 M6
Yes this is awesome! Got one 2 years ago and love it! You key it to code your ignition key! Easy
2010 Camaro 2SS/RS
BRAVO 2SS is offline   Reply With Quote
