Old 06-06-2021, 12:09 AM   #1
wstuarttn714
Drives: 2010 Camaro 2ss
Exhaust drone
Can I please get some ideas on how to reduce drone on Borla type s exhaust
Thank you
wstuarttn714 is offline   Reply With Quote
Old 06-06-2021, 12:20 AM   #2
xdamxincx
Drives: zl1 blk
some insulate the spare tire compartment....
xdamxincx is offline   Reply With Quote
Old 06-06-2021, 12:35 AM   #3
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
L99 OR LS3???
lemontwist is offline   Reply With Quote
Old 06-06-2021, 06:41 AM   #4
Fred 6528
Fred 6528's Avatar
Drives: 2011 ss
J pipes
Fred 6528 is offline   Reply With Quote
Old 06-06-2021, 10:01 AM   #5
Cheap Guy
Cheap Guy's Avatar
Drives: 2011 Camaro SS
Originally Posted by Fred 6528 View Post
J pipes
This^^^. That's why I went back to stock until I can afford to do it right. The drone was making me hate driving the car and it was right at the sweet spot of 70 mph. That's why I tell people don't judge an exhaust by the sound clips which are usually just a short acceleration clip or revving up in the driveway.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold
Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current
Cheap Guy is offline   Reply With Quote
Old 06-06-2021, 10:32 AM   #6
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Ah yes...here we go again...
Put the stock mufflers back on....LOL
Best setup in my opinion, catless longtubes, x-pipe, stock mufflers. Sounds nasty at WOT, great at idle, ZERO drone...
Speed Engineering longtubes - $350
Summit X-pipe - $100
Done.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 06-06-2021, 12:24 PM   #7
Modernmusclecar
Modernmusclecar's Avatar
Borla isnt known to have drone. Are you an l99 and if so are you talking about the afm engaging? J pipes shouldnt be needed on the better catbacks.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
Modernmusclecar is offline   Reply With Quote
Old 06-06-2021, 12:30 PM   #8
lemontwist
lemontwist's Avatar
i have the magnaflow cat back afm tuned out and i like it. very little to no drone i took it of my ls3 car it was awesome on the ls3 okay on the l99.
https://www.tunersports.com/images/p...729--15089.jpg
the main part of the magnaflow that helps the drone is the resonator x pipe. technically the magnaflow in the link has 3 mufflers
Old 06-06-2021, 01:07 PM   #9
CPCNY
CPCNY's Avatar
Drives: 2010 2SS/RS, VR ext/Blk Int
I have a borla S type and get drone around 1800 rpm.
CPCNY is offline   Reply With Quote
Old 06-06-2021, 01:50 PM   #10
Modernmusclecar
I didnt think that was an issue. Add headers op.
Old 06-06-2021, 05:16 PM   #11
SSJ2
SSJ2's Avatar
Drives: 2010 2SS CAMARO
I second the jpipes. Made all the difference
BBK Long tube headers, Hi flo cats, straight pipe muffler delete with j-pipes. K+N CAI, Soler Performance Ported Throttle Body, Soler Performance Throttle Controller, Phantom Grill, MGW flatstick shifter. 3.91 Gears, Ported Rod Mod Intake, ZTA Spoiler, Rohana RC22 20x10 20x11.
SSJ2 is offline   Reply With Quote
Old 06-09-2021, 09:55 PM   #12
ykeeta
ykeeta's Avatar
Drives: 2010 LS3 2SS/RS
Yup, adjustable J-pipes from Solo solved my drone nightmare as well.
CAI Intake, Kooks LT Headers, High Flow Cats, Borla Type S, JDP Stage 3 Cam, TSP .660" Spring Kit, 3.91, Posi Mod, Elite Engineering Oil Catch, BMR Trailing Arms & Subframe Bushings, NGK TR6IX Spark Plugs, Ported TB, Short Throw shifter.
ykeeta is offline   Reply With Quote
Old 06-10-2021, 03:20 PM   #13
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
+1 more for J pipes.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 06-10-2021, 03:31 PM   #14
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
How does that sound?
Don't have a video somewhere?
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
