01-31-2013, 09:05 PM | #1 |
Drives: Chevy Join Date: Oct 2011
Intercooler question
What type of fluid is in the intercooler aaaannddd..how do you add fluid?
Thanks, Steve |
01-31-2013, 09:14 PM | #2 |
Drives: 2018 ZL1 A10 and 2013 GT500 Join Date: Apr 2012
I would do some research but it will be some sort of water/ coolant blend. You should have a fill cap at the top of your coolent resevoir to fill add funnel then pour fluid in.
01-31-2013, 09:16 PM | #3 |
How do you actually check the fluid level
01-31-2013, 09:19 PM | #4 |
dexcool and the little black cap on one of the intercooler circuit lines (first remove red engine cover and look on top of supercharger). Rotate the cap to up position and remove the little clip and pop off cap to top off. Once you refill the system and replace the cap + clip, rotate the fitting with the cap to the left. It is a closed system. If you havent drained the coolant out of the IC circuit, I doubt it needs to be touched. There isn't a reservoir like a GT500 if you were first wondering. You can add an aftermarket unit if you are so inclined.
01-31-2013, 09:44 PM | #5 |
Oops well I tried figured it would have its own resevoir.
01-31-2013, 10:12 PM | #6 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
That's one of the reasons it heat soaks so quick.
01-31-2013, 10:19 PM | #7 |
I used to be Dragoneye...
02-01-2013, 05:39 AM | #8 |
Here's the next question..can you add redline water wetter to the intercooler to reduce temp?
02-01-2013, 05:43 AM | #9 |
You can do that but I bet you will have to remove some fluid first to prevent overfilling and spilling it.
02-01-2013, 08:54 AM | #10 |
Drives: 2012 ZL1, 2009 CTS-V Join Date: Jun 2011
DexCool/water.
02-01-2013, 08:55 AM | #11 |
02-09-2013, 10:05 PM | #12 |
Drives: TBSS Join Date: Sep 2011
02-10-2013, 04:21 PM | #13 |
I used water wetter in my motor and it lowered the temp by 20 to 25 degrees or so..
02-10-2013, 04:37 PM | #14 |
Drives: 2012 ZL1 & 67 RS-SS TwinTurbo Join Date: Feb 2012
