01-04-2020, 06:17 PM | #1 |
Drives: 2018 Black ZL1 1LE Join Date: Nov 2019
Garage Entry/Exit Mirrors?
We have a two car garage setup as two single doors. Since I'm DD her I'll be pulling in and out often. Do y'all use any kind of cheater mirror setup to see where the front splitter corners are when pulling in? I was thinking of setting up cheap vertical mirrors on each side to see.
flip |
01-04-2020, 06:34 PM | #2 |
You mean like this? It’s a 12x12 inch mirror. I got a pack of 6 from Lowe’s for like $10. I have it mounted to a cheap TV mount I found on Amazon. I mounted it and positioned the mirror to where I can see the orange line at the start of the garage. I can see where my driver side front wheel is and follow the orange line to the stop. The car is parked in the same exact spot every time!
01-04-2020, 06:52 PM | #3 |
YES!!! Thank you. That's perfect. I'll get to work on a similar setup.
01-04-2020, 07:07 PM | #4 |
you can also string a tennis ball from the ceiling to hit the center of the windshield.
01-04-2020, 07:33 PM | #5 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Since I like all the free space at the front of my car I pull in past where I need to be then I use the reverse cam lines and line up with the marks on floor the garage door leaves.
01-04-2020, 07:41 PM | #6 |
Drives: 2016 SS Join Date: Oct 2019
Nothing wrong with lines and mirrors, but if you just practiced for the length of time it takes to buy that stuff, you'd have it down. I used to own an 89 Iroc, and visibility was great. The 16 is SO much harder to see out of. The first day I backed it in I bet I went in and out 5 or 6 times and had to get out a couple times! By the end of the week I'm rollin' in hot, with barely a second look. It's like anything else. Good luck!
01-04-2020, 07:56 PM | #7 | |
01-04-2020, 08:49 PM | #8 |
Drives: Camaro SS 1LE Join Date: Aug 2018
01-04-2020, 09:06 PM | #9 |
Great points and all appreciated. I work shift work and 16 hour turnaround days/nights so if I can eliminate any points of possible error when pulling in during dusk/dawn, that would be great.
01-04-2020, 09:12 PM | #10 | |
Drives: 2018 Camaro 2SS Join Date: Dec 2014
https://youtu.be/7CLaKVchMsQ Last edited by BWAYNE2008; 01-04-2020 at 09:27 PM. Reason: Adding pic |
01-04-2020, 09:45 PM | #11 |
I back my car, truck and suv in every time. Never pull straight in and with the new back up cameras its actually easier then pulling in. Then in the morning when you leave your right straight back out the door. Just say see ya.
01-05-2020, 06:03 AM | #12 |
Wow. Never even considered that. I'm going to try that first.
01-05-2020, 06:15 AM | #13 |
I finally got my wife to start backing in and she even likes it.
01-05-2020, 07:53 AM | #14 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
This is what I do. Roll in a little deep, put it in reverse and then back up to a mark in the floor using the reverse camera. I manage to have to rear bumper just inches off the garage door.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - Last edited by hotlap; 01-05-2020 at 08:06 AM. |
