02-15-2018, 06:45 AM | #15 |
My dealer told me (plus I've read it on other postings) there were newly designed nuts that needed to be installed and torqued. Is it possible your dealer only torqued and didn't install the new design? If so, they may have loosened again.
Clear Bra, Tint, Splash Guards, Ceramic Coating, Painted Spoiler and Rear Views
02-15-2018, 10:09 PM | #16 |
Drives: 2018 ZL1 A10, 2019 BMW X5 Join Date: Dec 2016
I had the new ones put on. Took about a week for the new nuts to arrive. They definitely resolved that issue...this sounds different. I’ll report back in a couple weeks after I get it over to the dealer.
2018 Nightfall Gray Metallic Camaro ZL1 - A10
Purchased 9/23/2017 |
02-16-2018, 09:37 PM | #17 |
Drives: 2008 Pontiac G8 GT with a procharge Join Date: Apr 2011
I took mine to the dealer today, they ordered new end links. Will be here next week. Hopefully that will fix the issue for me.
Sent from my iPhone using Tapatalk |
09-23-2018, 02:38 PM | #18 |
Drives: 2019 ZL1 Join Date: Jan 2014
Does anybody have the TSB number that includes the new nuts being installed?
09-23-2018, 02:39 PM | #19 | |
09-23-2018, 02:46 PM | #20 |
Drives: 66 Chevelle SS Join Date: Mar 2013
Actually it is the Chevy Customer Care normal of 2018. Wait until you get 3 years behind you. It gets worse.
66 Chevelle SS 396
91 octane Driver n/a 6.44@105.78 1/8th mile |
09-23-2018, 03:05 PM | #21 | |
Thank you Al Oppenheiser!
https://www.camaro6.com/forums/showp...&postcount=104 But even the new nuts may not work: https://www.camaro6.com/forums/showp...&postcount=140 |
10-12-2018, 01:53 PM | #22 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
So mine has a clunk. it sounds like from the drivers front. Dealer already looked and couldn't find anything loose, end links, etc. They are going to check it out in more detail on Tuesday. I had another person look at it, and same, everything was tight. What else could cause it? It's just like when I go over bumps, or if i turn the wheel left right really quickly it will make the sound? Could it be a bad strut?
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
10-12-2018, 02:21 PM | #23 | |
I still have the same clunk. Same as you describe. Dealer said they couldn't find anything loose either. However, their lift at the dealer is a 4 point lift so the wheels are all hanging. I'm suspecting that may have an effect on finding the culprit. I'd like to find a shop that has a drive on lift, and then have everything checked. The clunk only seems to happen when the suspension compresses or there is "twist" to the car, like 1 wheel goes up at a time over a speed bump.
10-12-2018, 02:22 PM | #24 |
i had one and went to 3 shops including dealer trying to get it figured out
ended up being a broken strut mount problem from when i had my new lowering springs installed ordered new strut put it in tightended everything up got another alignment and been good ever since
10-14-2018, 11:16 PM | #25 | |
IG: 2fast2nick
11-03-2018, 08:29 PM | #26 |
Fixed. Mine ended up being the lower end link on the front passenger side. The chevy dealer looked at it for two days straight, haha. They couldn't anything.. sooo do it yourself
I upgraded to the BMR links
IG: 2fast2nick
11-04-2018, 12:40 AM | #27 |
11-04-2018, 09:28 AM | #28 | |
IG: 2fast2nick
