09-25-2018, 03:08 PM | #1 |
Drives: 2018 SS 1LE Join Date: Aug 2018
All Season Tires
Has anyone purhcased the MRR M017 wheels and compared them to the OEM ones? Is the finish on them a match to the OEM wheels? I was thinking I could maybe buy 2 20x10's to replace my rear OEM wheels giving me a square setup then purchase some Continental all season tires for the winters here in Indiana. I know it's a track car but I would like to have the option to buy all season tires without having to have another set of wheels I dont have room for.
TIA |
09-25-2018, 03:56 PM | #2 |
Drives: '18 1SS 1LE Join Date: Sep 2017
Different color.
And the 20x10 fronts have a different offset than the rear 20x11, so I don't know about fitment.
'18 1SS 1LE Black, PDR
09-28-2018, 11:39 AM | #3 |
Razzi
Drives: 99 Monte Carlo Z34 Join Date: Jul 2008
I have the same question and trying to do some reading. I live here in Indiana as well and will drive this when it gets cold. I'm looking at wanting to get 4x MRR M716 19x10 +23 and wrapping them in 285-35-19 for a square setup as well. Looking at how this would change the car with the rears being 20x11 +43 and looks like it would work but wondering if there is anyone else out there doing this. The Rear would stick out about 0.28" more but if people can run 315 in the rear and the only issue is inside rub this should work.
Front Change Rear Change |
09-28-2018, 03:58 PM | #4 |
Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
I have a set of Apex Arc-8's in 19x10 +25 and 285-35R19s all seasons at all 4 corners. Not really any noticeable poke or difference. You won't come close inside on the rears, you're giving up almost 1.3 inches on the inside edge compared to the stock. I've got about 9k miles on this setup as is.
If anything, the car feels faster because the smaller wheels give up almost 10lbs per corner. just less dry traction at lower speeds. |
10-15-2018, 10:03 PM | #5 |
Razzi
Does anyone see an issue with this square setup?
CURVA C300/ Rim Diameter: 19 Rim Width: 10 Offset: 30 Bolt Pattern: 5x120 Hub Bore: 73.1 Front Setup Rear Setup |
10-17-2018, 04:57 PM | #6 | |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
MJK3888 Instagram Link
10-17-2018, 04:59 PM | #7 |
"M1SS1LE"
and if you don't like the slightly inset look of the SS wheels then run 20mm hub centric spacers.
Just FYI 255/35 fronts fit better for 1LE instead of SS 245/40
