11-01-2016, 11:59 AM | #43 |
And I wonder if you add LTs, MSD intake, and CAI to go with that combo?
11-01-2016, 01:04 PM | #44 |
Drives: 2017 1LE Join Date: Sep 2016
Cam and heads 2400
Msd 1000 Lt 1700 Cai 450 Install 1500 or more Tune 650 7700 ish Or lt4 supercharger from ADM for as little as 6000 |
11-01-2016, 01:07 PM | #45 |
while this is a excellent point, but the thing im thinking about the heads/cam is no weight penalty. I have the magride and the ZL1 team said they needed to tweak the magride tune for the extra weight up front. idk how significant any of that is tho
11-01-2016, 01:20 PM | #46 |
It cannot be that significant, the magride does not need to be tweaked because you have a 170 pound driver instead of a 250 pound driver. Or 4 people in the car.
Having spent the last couple of years in a car with magride, I can tell you it does not give a shit. It adjusts and moves on. That's the idea it's constantly adjusting. |
11-01-2016, 02:54 PM | #47 |
Drives: 2016 1SS White MT Join Date: Aug 2011
ADM changed their price to 7k now .
2016 White 1SS with Port & Polish Heads and Cam by Texas Speed , Forged Drop in Pistons and Rods by Cunningham M , Procharger D1SC , Air to Air Race Intercooler, Race Valve , Helical Gears , Alky Meth Kit , Zl1 Low Side Pump , LT4 HPFP , V-Max Ported TB , MSD Atomic IM , ARH 1-7/8 Catless , Borla S Type Cat-Back . Work done by Lashway Motorsports 790RWHP-649RWTQ
11-01-2016, 03:27 PM | #48 |
Drives: 2017 Camaro SS Join Date: Aug 2016
11-01-2016, 05:07 PM | #49 | |
But there is something to be said for keeping the NA SS right aorund stock weight. The H/C car will have plenty of power for anything you might want to do. Heat soak will not be problem and the other suspension and driveline components will not be as highly stressed if FI car uses all its power. More things will break. I have owned a bolton 5th gen 1LE and then added FI to it. I also have owned a 5th gen ZL1 and I much preferred the ZL1 over the FI 1LE even though the 1LE was faster. I also spent more in the end on the 1LE than a ZL1 convertible. If you want to FI your SS, drive around on the street, and take it to car shows, then adding an SC may do it for you. But if you want to make full use of what you built you will spend some bucks and in the end you may like the original car better. That happened to me and I am not repeating my mistake with this car. Just my opinion. If I want a V8 FI Camaro I will save up for a ZL1. That would be a much more enjoyable car to me.
11-01-2016, 06:16 PM | #50 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
Wonder what you'd get with a ported TB, intake and E85 flex fuel sensor and tune? Guys are showing over 50RWHP with a few bolt ons and flex fuel.
11-02-2016, 08:26 AM | #51 |
Yea that formula may be the winner HP to cost. I am going all in with the MSD.
11-06-2016, 10:26 AM | #52 |
Drives: 2016 Chevy Camaro Join Date: Jun 2016
The choppy-ness you refer too comes from the overlap which is determined by the duration split and the lobe separation. It could be a .700" lift but if it had a negative overlap, chances are it would not lope at all. By this cam having a 116.5 lobe separation, it puts this cam on the milder side of things. I'm more concerned with the 228/248 degree split. That's 20 degrees of separation and even on a 116.5 , it may require a higher stall converter. A good tuner can look at the specs before you buy it and know whether or not... My gut is a 3000 stall minimum to regain near stock drive ability...
11-07-2016, 11:54 AM | #53 |
Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
Bump for Updates?
11-11-2016, 08:25 AM | #54 |
Drives: 2016 2SS M6 Join Date: Oct 2016
GOT IT BACK FROM THE TUNER YESTERDAY AND IT SOUNDS AMAZING IM GOING TO TRY AND GET IT ON THE DYNO NEXT WEEK TO GET THE POWER, IT WAS STREET TUNED SO NO NUMBERS. BUT IT FEELS LIKE A BEAST AND THAT SOUND, YOU CANT GET THAT WITH A SUPERCHARGER. IVE HAD 4 FORCED INJECTION CARS/TRUCKS IN THE LAST FEW YEARS AND IM GLAD I WENT THIS ROUTE. THE GM ENGINEERS SAID TO EXPECT 565-580 WITH A GOOD LONG TUBE AND CAI. WE WILL SEE
11-11-2016, 08:29 AM | #55 |
GOT A QUESTION ON CAI I WAS LOOKING AT GETTING EITHER A Cold Air Inductions ONE OR A ROTO FAB LEANING TOWARDS THE Cold Air Inductions UNIT ANY FEEDBACK
11-11-2016, 08:42 AM | #56 | |
Drives: 2016 Camaro SS Join Date: Oct 2016
Thank you, Tim |
