05-08-2020, 12:53 PM | #1 |
Drives: 2018 Chevy Camaro ss Join Date: Apr 2020
Whipple HELP
Preface: 2018 SS A8 MODS: Axleback exhaust only
I recently installed a whipple with my father (who built cars/engines his whole life) and had nothing but issues. The install itself wasn't terrible. We followed all the directions and took our time so install took around 25 hours to complete. Biggest thing we had trouble with was putting the AC belt on but we had the dealership do it and they got it on for us. Now for the most frustrating part.... the tune. It has been a little over a month since the car has had the whipple on first start was great let it idle for a long time (all on the whipple supplied tune.) It was late so the next day we go for the first drive. Drive the car barely cruising around and once I gave it any throttle ANY throttle... spark blowout car sounds like its 2 stepping with any throttle at all. We changed the plugs during the install and gapped them to .035 just as the instructions had told us to do. Ok no big deal right? Contacted the whipple "engineer" that had done my tune and whom was assigned to my case and he told me to change the gap from the plugs from .035 to .027. Ok no big deal. We did so loaded his new tune with the appropriate gap that was expected same problem probably worse. The "engineer" has sent me over 10 revisions to the same tune and nothing will work still 2 step backfires under any load at all. Finally the guy finds "the problem." Tells me to go to the dealership and have my Operating System updated and tells me that will fix it. Call the dealership, schedule an appointment for the next day, costs about 200 dollars to have the OS updated, get the car back, load the new tune with the updated OS. DOESN'T WORK. SAME ISSUE. The engineer gives me another 3 more revised tune files and none of them fixes the problem. At this point we are pissed. I called whipple and asked if I could speak to a higher up to take my case and see what's going on with the car. They tell me no you have an engineer assigned to your case only thing you can do is correspond with him. It was the weekend at this point and I needed a break. Finally when Monday comes the "engineer" tells me "we have never had luck running plugs with that low of gap. Change it back to .035". NICE TUNE WHIPPLE $7,000 dollars worth for sure. Call a local tuner looks at the tune for 5 minutes and tells me everything wrong with it tells me i'm still getting spark blowout. We decide to go with BRISK silver plugs and gap them to .022 fixes the spark blowout car runs 90% better than it did. It still missfires at 4th and 5th gear around 5,500 rpm on up. This has been an absolute hell of a ride to go on and I'm still looking for feedback on what could be causing this issue. We did a smoke test on the supercharger itself and know its not leaking. We are getting 3 codes. The first code at this point is a throttle position sensor code, the second is a catalyst code (we aren't too worried about this one as we know it is getting messed up from having boost), and a MAF sensor code. Has anyone experienced cutting out at high rpms almost like a stutter with a supercharger? PLEASE HELP. edit: My tuner and I took a long look through the logs and found I'm running above average boost at almost 8.5 pounds.... note: 3.625 upper Whipple pulley. Could this be causing that cutout in high rpm's under WOT??? I know with longtubes and a full exhaust it'll drop my boost a bit so could that solve the issue?? Last edited by OnThr3; 05-10-2020 at 10:51 AM. |
05-08-2020, 01:39 PM | #2 |
Hopefully Kinglt1 will know whats going on, he is pretty experienced with the Whipple's. I've always had good luck with the NGK and gapped mine at 28. Lots of guys are running the Brisk and really like them. Wish I could help but just now sure what you have going one. Do you have HP Tuners? If not you should get it and you can log when ever you have issue. Mpvi2 is the best one and you should consider buying an Afr gauge from AEM and then with the MPvi2 you can add another 02 bung and hook that up so you can log your AFR also. Good luck
05-08-2020, 01:46 PM | #3 | |
KingLT1 and others have said it since day one: don't use canned tunes. I went custom right out of the box and it made the process so much better. Good advice by Laynlo: get yourself HP Tuners and the AEM wideband. Then you can see what's up.
05-08-2020, 02:12 PM | #4 |
I am no longer on a canned tune and I do have HP tuners MPVI2 thats how I was data logging for the whipple "engineer." my tuner is using a dyno and a wideband at this point. Could dirty valves be causing cutouts like this up top? I guess another point of failure right now is at 1100 rpm and 1400 rpm when I am barely touching the throttle it feels jerky almost like a misfire but not... I am logging misfires on all 8 cylinders btw just hard to find the source of the problem...
05-08-2020, 03:28 PM | #5 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
I am no whipple expert at all, however, I have experienced similar symptoms on an older 90s automatic v8 that was bone stock. It turned out to be completely clogged catalytic converters. The car was trying to exhale through a pinched coffee straw. I had part throttle issues as well as complete choking 1500 rpm below redline. Well, I took a hammer and a spike, gutted both cats, put the pipe back on, started it up and all was cured. I've heard of forced induction clogging cats before, and a bad tune can definitely do it. Whatever the problem turns out to be, hope you fix it soon, I'd be devastated in this situation.
05-08-2020, 05:58 PM | #6 | |
05-09-2020, 12:15 PM | #7 | |
UPDATE: Bought headers and X pipe to REMOVE the pesky cats once and for all.... 2 codes to go.. |
05-09-2020, 01:23 PM | #8 |
Sorry to hear you are having issues. Without seeing your tune it's hard to say what is wrong. I doubt it's the plugs. I run NGK 7 heat range with no issue. I also doubt you ruined the cats that fast unless you were running really rich and doing wot pulls. I would suggest a competent Gen 5 tuner. Ted Jenetty, EFX tuning, GPI...etc. Don't think Pray Performance will remote tune FI cars anymore unless they have forged pistons.
That being said the codes are the reason it's running the way it's. Just have to figure out why they are popping up. Could be the harness that breaks the IAT sensor out of the Maf so can read Manifold air temp?
2016 NFG 1SS A8
05-10-2020, 02:47 AM | #9 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
I don't have a Whipple either, but recently added an LT4 supercharger to my stock LT1.
I can't help you with the codes, but... I remote tuned with Jannetty and as much skepticism I had of doing a tune from another continent - he zeroed me in after just 7 logs/programs - obviously following his profile and sneaking up on the final tune to preserve the engine. With that financial investment, certainly should cut your losses and go with a known quantity on Gen V LT's or else experience (more) damage. I'm running one heat range cooler plug gapped at .040 (LTR6IX-11). Absolutely no issues to 6800 rpm.
05-10-2020, 10:41 AM | #10 | |
05-10-2020, 10:42 AM | #11 | |
05-10-2020, 10:45 AM | #12 | |
05-10-2020, 12:55 PM | #13 |
Don't believe you ought to lump all remote tuners in with Whipple who specializes in making superchargers for various cars.
I would always search out the expert on that particular model vice a local especially with the current direct injection offerings. Admittedly, I also insisted in using a dyno vice just street tune. Likely you have more of an installation or car issue than a tune issue. A tuner won't fix codes - I even had that when I didn't connect my EVAP and had an error. Jannetty insisted that I correct before continuing - I wasn't going to argue. Good luck on your project.
05-25-2020, 02:08 PM | #14 |
UPDATE: The MAF code is fixed and the cats are fully gone with the help of the longtubes and x pipe 2/3 codes have been solved. In addition the little stutter at 1100rpm and 1400rpms were being caused by the car switching into v4 mode TOTALY FORGOT ABOUT THAT. Anyways we disabled the AFR and solved that problem as well. WE HAVE ONE MORE CODE and CANT figure it out guys :C
P0121 trottle position sensor code! symptoms: hesitation/stutter when given heavy throttle. If anyone has any input as to what this could be please let me know!!!! |
