10-19-2017, 11:59 AM | #1 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Clunk in rear end when making sharp turns
Anyone else had this noise shop up yet? I only hear when up to speed (say 30-45 mph) and then I make a fast left or right turn, I hear a clunk. I crawled under the car not too long ago to make sure the half shaft bolts were tight, and they seemed to be.
Anyone else run into this sound coming from the rear end area? |
10-19-2017, 12:57 PM | #2 |
Resident Land Surveyor
Drives: 2016 Camaro 1SS - Summit White M6 Join Date: Aug 2016
Last year when it turned cold I had that noise, and am beginning to again this year in the mornings. For me, I know it's the rear diff, but have yet to change the fluid. Need to do it soon, as now I'm at the recommended mileage to do so under the maintenance schedule. (45k)
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned |
10-30-2017, 03:23 PM | #3 |
Drives: 2016 Camaro 2SS (on order) Join Date: Mar 2016
Heard a clunking/groaning sound resembling that this morning. The temperature was in the 30's, but I only have around 12,000 miles.
2016 Camaro 2SS Garnet Red
V8, Dual Exhaust, MRC, Nav, Sunroof, Loaded "Ahhh! Take care to get what you like or you will be forced to like what you get!" - Lyrics from a song from Scooter: "Apache Rock the Bottom!" Previously owned 1998 BMW 540 w/M-series package 1991 Trans Am GTA 1985 Saab 900 Turbo (Burned leaded fuel on the Autobahn) 1985 Firebird (R.I.P.) 1976 Camaro LT |
10-30-2017, 04:11 PM | #4 |
These diffs make noise when cold...just no way around it. I changed my fluid 3 times @ 1200 miles. It went away and then I noticed it starting back up now the weather has turned. It only does it for a couple turns, then goes away. I am guessing its something with the clutches not slipping when cold...acting like a spool.
2016 NFG 1SS A8
10-30-2017, 05:28 PM | #5 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
My diff doesn't make noise. Change your fluid. Use the manual recommended fluid by gm. Already has the limited slip additive in it. If it doesn't get rid of the groan the first time, change it again.
My moms CTSV groaned when cold, took 2 diff fluid changes 500 miles apart to get rid of it for good.
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
10-30-2017, 05:56 PM | #6 |
already done that...along with several others. It comes back regardless when the temps drop down below 40.
2016 NFG 1SS A8
11-02-2017, 09:14 PM | #7 | |
09-14-2018, 12:34 PM | #8 |
Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
Sorry to bring this almost year old thread back, but has anyone figured out what the cause of this rear end “thud” or “clunk” is yet? I’ve got the same darn thing going on and it’s pissing me off big time.
09-14-2018, 01:25 PM | #9 |
Thank you Al Oppenheiser!
Check the sway bar end links and every other bolt and nut in the rear suspension.
09-14-2018, 07:15 PM | #10 |
Mine was actually dumbass moment for me, it was one of my tools in the trunk. I found it, no more clunk for me now.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
09-15-2018, 09:30 AM | #11 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Thanks for your honest respnse.
2012 Yukon XL Denali w/ 6.2 AWD |
09-17-2018, 12:05 PM | #12 |
