05-09-2018, 08:53 PM | #1 |
Drives: 2018 2SS Convertible Join Date: Mar 2018
Jacking your Gen 6 Camaro
I have been looking on line for the answer and watch Lethal Camaro videos. He recommended a company called ZL1 Addons. He gave them a great recommendation and demonstrated their products. Convinced to buy, I was looking at the website and I am confused, on the equipment they sell it says convertibles don't need this part. OK, I E-mailed them last week asking what do I need to buy and have not received an answer as of the following Wed. I was going to spend money and apparently they have all they need. So I am still in need of whatever part I need to jack up my car without hurting it. Any recommendations would be helpful and I thank you in advance.
05-09-2018, 09:32 PM | #2 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
You don’t need the fancy ZL1 thingies to jack up your car. Just take either a block of steel or a block of hardwood and cut a groove in it equal to the width and depth of the pinch weld ( about 1/4” wide x about 3/4” deep). Use this between your jack and the car and you are good to go. Most jack stands don’t need anything to work on the pinchweld.
05-09-2018, 09:39 PM | #3 |
Drives: 2017 2SS convertible M6, NPP, MRC Join Date: May 2013
When I looked at their site months ago, they recommended the Gen5 model of their lift point adapters for Gen6 convertibles. When I emailed the company for clarification, I too was ignored. Gen6 convertibles have a reinforcing X-shaped brace that occupies one of the two front crimp weld points. I've learned on this forum that a jack can safely be placed under the bolts that attach the X frame to crimp weld spot. Maybe someday the factory will build in flat areas for lifting.
Did you hear about the restaurant on the moon?
Great food ------ No atmosphere. |
05-10-2018, 07:10 AM | #4 | |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
the specified a sent for the 2017/18 convertibles.
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
05-10-2018, 07:20 AM | #5 |
Drives: 2018 Camaro 2SS Redline Convertible Join Date: May 2016
I have the ZL1 Addons bolt on jack points for convertibles for my SS Redline Vert and they work great. I use them for jack stand placement, and use the cross brace bolt locations to raise the car prior to sliding the jack stands under the bolt on jack points. If I'm not using jack stands, I jack directly under the jack points.
2019 Buick TourX
2017 Colorado Redline 1966 Ford Mustang Pro Touring |
05-10-2018, 02:49 PM | #6 | |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
05-10-2018, 03:17 PM | #7 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
The DEDC medium slotted pucks are what I use for both jack and jack-stands. They're excellent.
05-10-2018, 04:27 PM | #8 |
Drives: 2017 Camaro 2SS Join Date: Mar 2017
ditto
2017 NGM 2SS NPP M6 MRC Vortech SC, 2" TSP LT No Cats, Borla X, Eibach, Hurst shifter 603hp/547tq |
