Old 04-17-2018, 08:56 PM   #1
soceur77
Drives: 17 NFG ZL1 17 GTR 22 RS6
Sealed vs ported boxes
Sup guys, about to grab a pair of Sundown SA 12s and I cant find a ported box meant for a 6th Gen anywhere...(as in from a place like ********) So Im assuming most or using sealed boxes here? Or utilized prefab or custom made boxes?
Also do you think ill be ok running those subs on a Sundown 1000 or should I step up to the 1500D
thanks for the input!
soceur77 is offline   Reply With Quote
Old 04-17-2018, 09:36 PM   #2
motorhead
Do you like the dong or a controlled tight base? It comes down to the musicyou like.
Old 04-17-2018, 10:52 PM   #3
soceur77
well i actually found a ported Sundance box for two 12s but im not sure if it will fit. Size is 36"wide x 17"tall x 16.5" deep and built to spec for the SA 12s
Old 04-19-2018, 09:29 AM   #4
rc610
rc610's Avatar
Drives: 2020 2SS SGM - Stock for now
rc610 is offline   Reply With Quote
Old 04-19-2018, 09:31 AM   #5
rc610
rc610's Avatar
You have roughly 14” of height in the 5th gen trunk unless you remove or raise the 6x9s. I’m planning to build in the trunk. Other than that you’d be better off sealed. I’m running 2 individual sealed boxes until I get around to building my ported enclosure. Another option would be to drop to 10” subs. Lastly, depending on the version of sa 12 they’re “rated” anywhere from 600rms-750 rms I believe so you would be fine with the 1500 watt amp but could likely go bigger. Just be sure you can provide the proper voltage.
Old 04-28-2018, 07:42 AM   #6
Miami_1LE
Drives: 2018 Camaro SS 1LE
I've had both ported and sealed box's in my Camaro. Subwoofer in a JL Audio 12w7 so it bangs. Ported was nice but to be honest sealed is where its at. All these people talking about sealed being quit are dumb. My sealed set up destroys ported on most notes. The sound quality ported lets say was a 6 out of 10, sealed is a 9 out of 10. Way better sound quality sealed and you feel the bass much more. I will from now on always do sealed set ups. Go sealed trust me. Trust the crust.
Miami_1LE is offline   Reply With Quote
Old 04-30-2018, 08:52 PM   #7
Markoz28
Drives: 18 ZL1 nightfall grey A10
I’m looking at putting 2 JL 10w3 with 1000 watt amp in sealed box but concerned about weight. What do you guys think?
Markoz28 is offline   Reply With Quote
Old 05-01-2018, 03:43 AM   #8
red_johnny
red_johnny's Avatar
Drives: 2016 Gray 2SS M6
This. I once had a ported box (long time ago) and converted it to a sealed. The difference was unbelievable! I like how neat and clean the bass is compared to a ported box.
red_johnny is offline   Reply With Quote
Old 05-01-2018, 03:45 AM   #9
red_johnny
red_johnny's Avatar
Why are you worried about weight? If you are going for a particular sound or set up you must make sure everything is constructed as best as it can be. This sometimes means more weight but in the end the sound quality can be much better. Just depends what you are trying to accomplish.
Old 05-01-2018, 11:47 PM   #10
black96lt1
Drives: 1996 z28
Ported boxes can have good sound quality they just have to be designed properly. Sundown SAs are designed for a ported box but I've has a sa-12 in a sealed box and it sounded good. But really came alive when I put it in a ported box. And they would be fine on the 1500 just make sure the gains are set properly.
black96lt1 is offline   Reply With Quote
Old 05-02-2018, 02:55 PM   #11
drfeelgood
drfeelgood's Avatar
Drives: 2017 ZL1 Convertible A10
Free air, ported, sealed boxes can all sound good, with the right design, in the right acoustical environment, using the right subwoofer. Same sub, places into each of the three types of boxes, even built to spec will sound different. Amplifier choice will also affect the overall sound. There’s no right or wrong, just different based on what you want
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq)
'17 Maserati Levante- STOCK
drfeelgood is offline   Reply With Quote
Old 05-22-2018, 11:00 PM   #12
Miami_1LE
10w3's dont weigh much. Do it. Now my 12w7 is heavy as hell.
Almost 100lbs added to the car between the sub and box.
Old 05-25-2018, 08:20 PM   #13
cengell
Drives: 2017 2LT Garnet Red
Hi all, well I finished my dual 12 Subs, I used 2-JL Audio 12TW3-D4 12" and I must say WOW! I am in a 2017 2LT and made a custom sealed box, making as large as possible and have almost 1.78 CF and that's perfect for the 12TW3-D4 wired for 1 ohm using a Rockford Fosgate Prime 1200 watt and set the gain not to be more than 1% distortion so I don't damage these 800 watt subs. When the top is up I get some pounding bass and when the top is down not as much but with some MP4 music I am very impressed and I think for a Camaro hard to beat and still have the trunk space useable.
Christopher
cengell is offline   Reply With Quote
