03-30-2024, 10:16 PM | #1 |
Looking for rear subframe bushing washers/hats (takeoffs or part number)
I'm hoping someone out there has a set of these that they removed for solid bushings. I literally only need the washers that the bushings sit on. The bigger one is somewhat cone shaped.
Mine are damaged and while I would love to throw solid mounts on there, I just don't know when I'm going to be able to get it done. I can swap out the metal washers real quick for a quick fix for now. I'm not finding these on any parts sites, unless it's considered part of the whole subframe, but that is showing discontinued.
03-31-2024, 09:39 AM | #2 |
Drives: 2013 1ss Join Date: Jul 2012
I had the same problem trying to find these. GM would not sell these seperately and I could only get them new if I purchased the entire subframe. Dealer suggested going to a salvage yard and see if they would sell them.
I took time and repaired and reshaped my old ones and reused them. |
04-01-2024, 05:23 PM | #3 |
Yeah I'm afraid of this. I may reach out to hawk and see if they can get me a set for cheap, otherwise I may be forced to go the solid route...
At least one of mine is totally beyond repair, like the steel is basically crumb cake, and the others are not much better. I'll try to get a picture later just to show you the horror of it!
04-02-2024, 06:58 AM | #4 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I suggest you install the solid mounts, with the right tools it is not a bad job.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
04-02-2024, 05:07 PM | #5 |
Here's the horror show!
04-07-2024, 12:13 PM | #6 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Here is what I have.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-07-2024, 07:12 PM | #7 |
Those look much better than mine! I sent you a pm, if you don't need them anymore I'll happily take them!
