Old 06-20-2018, 02:49 PM   #1
1LE Azul
Drives: 2018 SS 1LE
Does your car sound like this?
This stingray sounds exactly like my car when I give light revs and hold. Could anyone check if their LT1 makes this same noise, and maybe even post a short clip of light, held revs if possible so i can confirm and put my nerves to rest if in fact it IS normal. I heard its loud injectors or something like that. I have a 2018 1LE for about a month with little under 1500 miles. First video is my own car, second video is the stingray. Mine starts being more obvious at about 58 seconds in, the corvette is obvious from the moment he starts holding his revs
https://youtu.be/dhBXiJwo5iM
https://youtu.be/V_JlSlbJGZ4
Forgot to mention that this same tick/rattle is pretty audible in the cabin with windows up, ac on, and no music from 1st to 3rd gear from about 1500 to 3000 rpms just cruising and disapears when rpms are moderately high or under high acceleration. Does your car sound like this while also cruising?
1LE Azul is offline   Reply With Quote
Old 06-20-2018, 03:20 PM   #2
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
You have the mic so close to the engine, it sounds worse than it is. I don't hear any metallic tapping noise to be concerned about. Drive the car and enjoy it. These are not quiet engines.
torqueaddict is offline   Reply With Quote
Old 06-20-2018, 03:35 PM   #3
c120cut
Drives: 17 1ss vert garnet red
the tick/rattle is the hpfp
c120cut is offline   Reply With Quote
Old 06-20-2018, 03:42 PM   #4
torqueaddict
Not the same engine, but applicable as an illustration. This is the tapping noise you DON'T want to hear after the engine has warmed up. it is ok on cold startup as long as it disappears soon after from what I've researched:
https://www.mustang6g.com/forums/sho...d.php?t=105527
Old 06-20-2018, 05:36 PM   #5
1LE Azul
Drives: 2018 SS 1LE
That's why I uploaded the one from the vette, its the same noise but more distinct. And its not a metallic noise its a very rapid tic/rattle
Old 06-20-2018, 05:38 PM   #6
1LE Azul
Drives: 2018 SS 1LE
I heard the high pressure fuel pump has a role in this, im not a mechanic, but is that the same as the direct injection?
Old 06-20-2018, 05:42 PM   #7
1LE Azul
Drives: 2018 SS 1LE
Lol that's why I got rid of my coyote. I hope if that's your car, you get that figured out.
Old 06-29-2018, 06:51 PM   #8
SpazmXylam
Because Racecar!
SpazmXylam's Avatar
Drives: 17 SS 1LE
I'd place my bet on injectors. Normal.
SpazmXylam is offline   Reply With Quote
