Old 09-23-2017, 10:00 AM   #43
Mr. Texas
Mr. Texas's Avatar
Drives: 2016 Mosiac Black 2SS A8
I have the same issue after the tc flush and brake rotors being turned.
Mr. Texas is offline   Reply With Quote
Old 09-23-2017, 10:19 AM   #44
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
Between this, the extreme windshield fogging, TC issues, this $50k car is a joke.
Sent from my 5049W using Tapatalk
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
Adrian97c is offline   Reply With Quote
Old 09-23-2017, 09:03 PM   #45
Mr. Texas
Mr. Texas's Avatar
So i removed my tire and fender liner. I only see 2 bolts on top of the rocker panel area that bolt the fender down. Are these the ones you are talking about? I don't see anyway these will move it in or out. I think my bracket is bent?
Old 09-23-2017, 09:57 PM   #46
Adrian97c
Adrian97c's Avatar
Its difficult to understand at what angle or which direction you are pointing. Video would help in allowing us know the orientation of view. But I don't think you are looking at the right screws. The top screw you can see by opening the door & looking inward...
Gen5diy tried explaining it on post 25, but the pic he posted also confused me on orientation. Was the fender upside down? Driver side? Wish he could post few more pics diff angles, from further away, etc.
Seems like we are all lost
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
Old 09-24-2017, 04:07 PM   #47
Mr. Texas
Mr. Texas's Avatar
I was looking at the wrong bolts. But the one I circled were still my issue. I was able to find the 2 bolts and loosen them up and push the fender in. The fender still stuck out at the very bottom. The idiots at the dealer put the lift right under the rocker panel and jacked it up totally missing the pinch weld. You can see indentions in my rocker. It then bent the part I circled above causing my fender to push out. So today I removed the rocker and took pliers to the part i circled above and bent it back pulling the fender in. Only bad part is my rocker has a small dent in it that you have to lay on the ground to really see. So now do I even bother complaining to them about it? My rockers are already trashed with rock chips and the car has visible primer spots through the mosiac black paint they won't own up to so why would they care about this...
Old 11-28-2017, 02:50 PM   #48
Adrian97c
Adrian97c's Avatar
Door / Front fender alignment issue.
Could you post pic of how it looks now ? Before/after plz...
I still need to try to fix mine.. after an oil change last week looks like passenger side is pushed out too, but not severe like driver side.
You giving me hope! Plz respond soon as you can...
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
Old 06-19-2018, 09:26 AM   #49
Silverwing
Drives: Yellow 2018 SS
I realize this thread is old but has anyone gone to their dealer or found a fix for this?
Just bought my car and it was lifted wrong, underneath side rockers you can clearly see where the lift left an indention and "squished" the panels, plus my fender is slightly out of alignment too.
I don't really care about the rockers that much, I'll probably buy some side skirts to cover it, however the fender next to the door is slightly higher on the body line then the door is.
Any and all help appreciated.
Silverwing is offline   Reply With Quote
Old 06-19-2018, 09:28 AM   #50
Adrian97c
Adrian97c's Avatar
Could you explain how you removed the rocker? We need your help bro
Would Love to also see fenders now after you fixed it. Pic?
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
Old 06-30-2018, 06:14 PM   #51
Silverwing
Still wondering if anyone's figured this one out yet.
Old 07-10-2018, 05:56 AM   #52
Adrian97c
Adrian97c's Avatar
See post 45, I’m hoping he will return to this thread to tell me how to take the rocker off to fix the issue.
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
Old 07-18-2018, 04:51 PM   #53
Adrian97c
Adrian97c's Avatar
I asked him to make a video clip explaining what steps to take.
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
Old 07-19-2018, 03:43 PM   #54
HackSaw
HackSaw's Avatar
Drives: 2017 Camaro SS
I would like to know how to remove the rocker/uni panel to get at those bolts and brackets. Also when I was Installing ZL1 lift pads I found the white plastic clips that connect the bottom front of the rockers to the body were both broke. Guessing that when it was lifted wrong it put too much pressure on them
HackSaw is offline   Reply With Quote
Old 08-28-2018, 07:00 PM   #55
NYJets12
NYJets12's Avatar
Drives: 2018 1LT Camaro
Mines the same thing I found out when I opened my passenger side door and it squeaks. I don’t think it’s from the lift mine was on it once for the free oil change 6 months ago. My guess is from hitting the potholes something got knocked loose. Dealer is gonna fix it but said it’s not covered under warranty. Luckily my insurance is gonna cover it and it’s only $100 deductible.
There telling me I hit something and everything got pushed back even though there’s no dents. Or I hit a pothole and the tire hit the right front quarter panel and that got pushed back towards the door.
Sounds like it’s poorly built and the potholes knocked something loose
NYJets12 is offline   Reply With Quote
Old 08-28-2018, 08:53 PM   #56
Adrian97c
Adrian97c's Avatar
Please watch them fix it, tell them to take pics video of the repair! We need to know!!!
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
