03-13-2021, 09:38 PM | #1 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Cold start- is this normal
Had a tune redone, and everything runs great. However, when I start the car when cold, the RPMs start at 1200. After a minute or 2, it settles to 900.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
03-13-2021, 09:46 PM | #2 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Yes
03-14-2021, 01:29 AM | #3 |
Hmmm. Weird. My g8, nor my c6z never did that, where it’ll idle higher for a couple of minutes then settle down.
03-14-2021, 06:22 AM | #4 |
Yep, normal.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
03-14-2021, 07:07 AM | #5 |
Hmmm.
1 yes 1 yep and 1 weird. |
03-14-2021, 08:57 AM | #6 |
Yep, mark me for "normal". lol. Mine does that.
03-14-2021, 08:58 AM | #7 |
It don’t come easy.
Add me to the “yep” list.
03-14-2021, 09:24 AM | #8 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Yep
Sent from my Pixel 5 using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
03-14-2021, 09:29 AM | #9 |
The ayes have it
03-14-2021, 09:37 AM | #10 |
Thank you
03-14-2021, 10:00 AM | #11 |
Normal
03-14-2021, 11:12 AM | #12 |
Well, it's normal if your tuner set it up for that RPM when the coolant temp is at whatever. This can be changed if you dont like it. It's quite flexible.
03-14-2021, 12:21 PM | #13 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Cammed cars idle around 1000 rpm depending on the cam and the tuner. All my cars I ever owned started high and drop rpm once they are warmed up.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
03-14-2021, 01:38 PM | #14 |
My car on a freezing day will start at 1100 rpm and idle down to 750 in a minute or so.
Thread Tools | |
