11-07-2020, 05:42 PM | #1 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Belt woes...
Any recommendations on a replacement belt for ECS 1500? Belt was never put on correctly from the beginning. Got it straightened out a couple of months back, but I’m sure it messed up the structural integrity. Edge of the belt sheered off.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
11-07-2020, 05:52 PM | #2 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Look up gates - what numbersare on the belt?
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
11-08-2020, 03:19 PM | #3 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
You using an 8 or 10 rib?
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
11-08-2020, 05:30 PM | #4 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Gates green belt.
11-08-2020, 07:30 PM | #5 |
11-08-2020, 09:16 PM | #6 |
I have no idea. Haven’t checked yet. What am I suppose to for?
11-09-2020, 06:59 AM | #7 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Mine are 10 rib, but it should be something like K100749HD (10pk1903) K100745HD (10pk1893).
Ive also had good luck with the Continental Elite Poly-V belts. 4100577 (10pk1920) But like I said, those are all 10 rib belts in the 75 1/2'' - 75 1/8' range.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
11-09-2020, 09:53 AM | #8 |
I’m assuming it’s pretty easy to swap.
11-09-2020, 01:06 PM | #9 |
Dan
To take the belt off - use a 1/2 breaker bar and insert it in the square hole on the tensioner. Then take the pressure off the tensioner and you can slip the belt off - there should be a part number on the belt - you can then order a new one. Post up the part number - I may have one on hand - I have three others, maybe have the right length...
Dan
11-26-2020, 07:57 PM | #10 |
Finally had a chance to look at the car. NO P/N. :(
11-26-2020, 09:21 PM | #11 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Gates RPM belts if you can find your size...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
11-26-2020, 11:10 PM | #12 |
Dan
Call up ECS and find out was size was shipped.
Dan
11-26-2020, 11:23 PM | #13 |
Easy way to find out belt length?
11-27-2020, 03:38 PM | #14 |
Dan
Measure the inside circumference with a peice of string, then measure the string.
Dan
Thread Tools | |
