04-29-2017, 04:16 PM | #1 |
Drives: 16 2SS Join Date: Apr 2017
N2O
Anybody got any idea if a 150 shot is to much for a stock SS A8
04-29-2017, 10:48 PM | #2 |
No its not. Beasley ran 10.60's with 150 and no tune.
05-01-2017, 08:32 AM | #3 |
Drives: Black SS Join Date: Apr 2010
no tune and a 150 shot? sounds brave to me.
2016 2SS
BONE STOCK |
05-01-2017, 06:25 PM | #4 |
Drives: Camaro 17 SS Join Date: Jan 2017
It is not too much (My findings). I am trying to finalize my install and testing thread. But I can say that with a little tuning, colder plugs, and E85 stock motor does just fine. (all warnings apply)
05-01-2017, 06:29 PM | #5 |
05-01-2017, 07:59 PM | #6 |
I just know what he posted and he was asked by me and others.
05-01-2017, 10:26 PM | #7 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I'm completely clueless to n2o, how are you supposed to add more fuel for it? Since I don't know if a way you can modify the afr or airmass in the tune based on adding n2o? How is this normally done on EFI?
Sent from my XT1635-01 using Tapatalk |
05-01-2017, 10:53 PM | #8 |
I'm not saying that you are wrong or anything like that. Its actually the opposite. I was surprised. I worked my way up and everything was fine. These cars are amazing. But in all honesty I have pulled a little timing. But up to 100 HP shot I did not. I was on the stock timing table. And had ZERO knock and plenty of fuel left. So for me the next logical step was 150 and still no know and still plenty fuel.
05-01-2017, 10:55 PM | #9 |
I am using a wet kit. So it injects both fuel and Nitrous at the same time. You will not have to adjust for fuel. There are guys here running 100+ shot plus spark plugs on otherwise complete stock cars.
05-02-2017, 12:24 AM | #10 | |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
On a wet system do you have to pull timing? Can you run a wet system without a tune? |
05-03-2017, 05:54 PM | #11 |
As with everything moderation is important. I've seen that Manny people have sprayed stock motors, stock tune. I have not. My car was tuned before spray. I did revert back to stock timing table as a baseline. I am pulling timing for 150 shot and above.
05-06-2017, 11:05 AM | #12 |
Drives: 2016 CAMARO 2SS Join Date: Apr 2017
I would think if you wanted to be safe and spray a 150 shot on the stock tune a stand alone fuel system with 110 in the tank would be nice
05-07-2017, 11:07 AM | #13 |
What's "nice" and "needed" aren't always the same thing. The stock fuel system can support more than 150 on E. So on something like MS109 or higher you will still have plenty of fuel capacity. Beside if you buy a well assembled kit there are safeguards in place to keep you in check. JMHO
