Old 12-30-2015, 08:37 PM   #29
Allanski
Drives: Car
Hi Ted
Any experience and comments on Moran Injectors for the bigger hp cars?
Thanks
Allanski is offline   Reply With Quote
Old 12-31-2015, 06:32 AM   #30
Lawdog86
Drives: 2011 2SS Black w/Orange Stripes
I have a 2011 2SS, I am looking to add a supercharger, headers, ZLI fuel pump. I would like 700hp, but would be happy with 600. What would be your recommendation for the supercharger, and build. How much should I expect to spend installed for 600-700hp? Thanks!
Lawdog86 is offline   Reply With Quote
Old 01-04-2016, 07:38 AM   #31
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by VASTREETRACER View Post
Ted,
Im running the 65lb injectors that came with the blower with a zl1 pump and adm fpcm. The tune is from a local shop who does mainly LS cars. I believe he uses HP tuners.
Just back from vacation sorry for the delay in response.
I believe the problem is in the injector data.
Switch to ID-850s, plug in the data, retune the MAF to achieve commanded AFR at all Throttle positions, rpms, and all your problems will go away.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 01-04-2016, 07:40 AM   #32
JANNETTYRACING
Originally Posted by Venom SS View Post
Procharger P1 or D1
I see you offer both
What would you recommend with a L99 DD
The P1 would be best fit for L99 DD.
Ted.
Old 01-04-2016, 07:41 AM   #33
JANNETTYRACING
Originally Posted by camarosspower View Post
Hey Ted I've noticed that you have done lots of the slp tvs2300. I'm just wondering what maintenance is required on these blower. Also if I add a ported throttle body and a scoop will it affect the tune? Will I need to retune? It's a l99 613 rwhp and 560 rwtq 12 psi
At 100,000 miles you will change the gear oil in the case.
Yes anything you do to change from the tuned combination will require custom tuning again.
Ted.
Old 01-04-2016, 07:43 AM   #34
JANNETTYRACING
Originally Posted by Bennyb View Post
Ted,
I have an ECS 1500sl kit with a fore stage 1 kit. Currently, after going passed 3200RPM my stabilitrak goes on. I took it to the dealer and since my engine is modded they won't even mess with but did hook up the diagnostic machine (U2100) code came up. I can tell my power steering pump is going out so I just ordered the lingenfelter pump. I don't know if that will fix my issue, but can offer any suggestions on what can be causing this. Thanks in advance.
You would have to follow the diagnostic trouble tree for the codes you have.
You should also discuss this with your tuner.
Typcially stabiltrak is triggered by misfire, Plug wires or spark plug issues.
Ted.
Old 01-04-2016, 07:44 AM   #35
JANNETTYRACING
Auto or Manual?
Old 01-04-2016, 08:44 AM   #36
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Ted.
100k mi on the blower right ted? I think the blower has about 8k mi on it now
camarosspower is offline   Reply With Quote
Old 01-04-2016, 08:56 AM   #37
JANNETTYRACING
Yes at 100K on the blower you will change the gear oil.
Old 01-04-2016, 11:09 AM   #38
camarosspower
Thanks. I heard these were low maintenance but didn't expect that much.
Old 01-04-2016, 12:43 PM   #39
trans665
trans665's Avatar
Drives: 2013 2ss
The LPE twin pump system is a good one we don't like to exceed 750 rwhp auto and 800 rwhp manual with it.
Ted.
So what fuel pump do you recommend for a 830 rwhp horsepower goal.....with the ecs setup on a auto
2013 auto ss..full bmr suspension..3800 stall...s475 turbocharger on 16 psi with 150 nitrous outlet plate...,BTR stage 3 turbo cam.....100% Methanol injection....LY6 6.0 iorn block ...
trans665 is offline   Reply With Quote
Old 01-04-2016, 01:41 PM   #40
JANNETTYRACING
Squash or Fore innovations.
Old 01-04-2016, 03:19 PM   #41
Lawdog86
JANETTYRACING, I have a manual.
Old 01-04-2016, 04:19 PM   #42
trans665
trans665's Avatar
Drives: 2013 2ss
If I order the kit from you guys can you substitute the 60 pound injectors for a different size. I'm thinking I'm going to need 80 pound injectors to reach my goal I already have the cam the LS conversions and the aftermarket casting ported heads. Waiting for income tax for the ecs kit..also I already got the 3600 triple disk. And want to order the watermeth at the same time I get the supercharger
I just looked on your website and I don't see the Ecs system
