09-10-2014, 03:17 AM | #1 |
Drives: '16 C7 Z51 Join Date: May 2012
2014+ Camaro SS brake ducting install
Why do you need it?
For anyone who intend to use their cars at the road-course track, brake ducting is a must. Even if your brakes did not fade at your local track (perhaps it has very long straights), it is a known fact that our cars are just too heavy for the 4-piston brake system to handle at the track, and you're most likely overheating the system even if not enough to fade. Cooler brakes also use pads at a slower rate: $$$! Any potential issues with it?
Note: Updated instructions to reflect the routing which does not rub at all and does not interfere with suspension parts. Tools to use:
STEPS:
This is the passenger side of the car. The area behind the grille which is currently covered with a plastic shroud is the location for the brake ducting. Driver's side after the shroud was cut. Please note the three bolt provisions for mounting. Driver side, after the shroud was cut. Preparing the ducting before mounting... NACA ducting in its place (test fitting) The rib cut for better air flow, and ducting mounted. How it looks from inside the bumper UPDATED Brake ducting layout: Finished:
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD Last edited by X25; 02-03-2015 at 06:55 PM. |
09-10-2014, 05:51 PM | #2 |
Drives: 2012 1SS/RS Join Date: Jun 2013
Are you sure there is enough slack to allow steering lock? One consequence of not wrapping around the strut is all of the length change you get going from lock to lock. I did the around the strut and back to the duct method and still had the sway bar end link bolt (the threads sticking out on the inside of the sway bar) eat a whole in the duct... If your routing is working it would be a great solution, less duct, less restriction, less sway bar end link interaction.
"Driving is the only thing I love about f1."
(Kimi Raikkonen) |
09-10-2014, 05:58 PM | #3 | |
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
09-11-2014, 05:56 AM | #4 | |
(Kimi Raikkonen) |
09-11-2014, 06:17 AM | #5 |
I finally finished the rest of my work (tranny oil change, race pads, new rotors, etc.), and revised the route a little bit as a result of more fitment testing with the tire and car lowered. During my test drive that followed, it never rubbed the hoses, but when you do full lock during a parking maneuver, it does touch a tiny bit. I will do the ultimate test over the weekend during my 500-mile-trip to the track and the track day itself. If it survives, I am sure it will last a long time : P
09-12-2014, 08:12 PM | #6 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
11-09-2014, 03:25 AM | #7 |
Finally found a perfect layout and updated the instructions! Basically, this layout will not rub no matter what size your wheels of how low your ride is, since it is never getting close to any moving suspension part. I thoroughly tested it this weekend at the race track, and it still looks like new : )
11-30-2014, 07:49 PM | #8 |
BeckyD Rocks :-)
Any idea of the length of hose we'll need for each side?
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade. Stage 3 BMR cam, ARH 1 7/8 headers, CAI,
BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings...460 whp...so far....SOLD, but not forgotten! |
11-30-2014, 08:22 PM | #9 |
I am not sure if I remember correctly, but I think I bought a 10-feet-long hose, split it in half, and it was comfortably enough, but I did not have any unused left! This is for the updated route.
12-07-2014, 09:07 AM | #10 |
BeckyD Rocks :-)
Though I hate the idea of cutting any part of that lower grill, looking at what you've done, it would dictate to cut that part in front of the duct inlet so as to not divert air over and around the inlet. It would seem that you would get direct air to go into the inlet that way. Great job.
12-07-2014, 11:21 AM | #11 | |
02-03-2015, 05:18 PM | #12 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Well damn, this got figured out. I might do these one of these days...
Sent from my SM-G900V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
02-03-2015, 06:52 PM | #13 |
Drives: Chevys at the limit Join Date: Nov 2010
Excellent write up!
Best regards, Tyler 888-308-6007 |
03-11-2015, 08:44 PM | #14 |
BeckyD Rocks :-)
Almost done I set my inlet ducts a little different than you have as I include the Apex Scoop for the CAI. My only concern is that the hose is close to the area that I circled in the photo below. I fear that this will cause rubbing and wear in that area. I'm thinking of deforming that area to give it an angle for the hose to bypass to ride up that column if need be. Any opinions would be appreciated I did put a zip tie on the rod running parallel with the strut, but it's still very close when I put the tires on and let it sit at normal stance. I didn't take any pictures at that point because it was getting late. I'll take some more pics when I get another chance.
