09-03-2022, 01:55 AM | #1807 | |
Drives: '17 ZL1 Join Date: Jul 2016
It's going to get convoluted regardless. I'd also argue that a tire can and often does make more difference than ZL1 vs ZL1 1LE or SS vs SS 1LE. Most modifications people list make very little, if any, lap time difference. Tires are a huge factor though. There's a lot of value in seeing differences in lap time per tire with all things equal due to classing differences at times events. Or, perhaps someone might just want to see the best lap time achieved on a particular tire at a given track. I don't know. Lots to consider. I'm thinking there is value in keeping multiple times when the tires are different if the list is to serve as a point of reference. If it's just for bragging rights, then maybe a 1 entry per person per track makes sense. Just my 2 cents. I now actually own a 23 ZL1 1LE and I have an 23 SS 1LE on the way. I'll be starting to track these other cars soon. I suppose we'll see what works out going forward.
09-03-2022, 09:30 AM | #1808 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
Totally get the different tires deal, but building the list off of that would make it super hard to compile and keep track of. (I just set a PB on the Toyo RRs this week, but it is still 1.6 sec of my 3R times, so no post)
@travislambert Can't wait to see your new builds! Ken
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
09-03-2022, 10:06 AM | #1809 | |
Using my last post as an example, it seems odd to have a rule that precludes a 1:50 lap on supercar 3s from being posted yet a person could post a 2:30 lap which doesn't add much value to the list and that would be posted right away. There's just something off with that. If the burden of list maintenance is the issue, then maybe limiting each track to the top 10 fast times or something would solve that. The lists would settle and maintenance wouldn't be a burden at all, yet the lists could still provide really good reference laps for someone looking to learn the track or possibly choose their next set of tires. If the same person can occupy all 10 spots with unique configurations, then so be it. Or if the list is meant to be based around the person, then make it one entry per person. When my other cars get track ready, I'm pretty sure each car will occupy a spot at the top of the PittRace list. When that happens, I bet someone proposes a rule change to prevent that scenario too. That's my original point. It's either based on the person or the car. When you choose car, it gets complicated. Model and trim are not enough to make it meaningful. That's why every time trial organizer has complex car classing rules based on much more than model and trim.
09-03-2022, 09:03 PM | #1810 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
Track= Grattan Raceway
Elapsed Time = 1:26.64 Year / Model / Trim = 2018 Camaro SS 1LE Date = 9/03/2022 Tires = Goodyear Eagle F1 (factory) Mods = DTC60 pads and SRF brake Fluid |
09-04-2022, 08:13 AM | #1811 |
Nice Grattan run... I cannot STAND the patches there. Sounds like understeer lol
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
09-04-2022, 11:55 AM | #1812 |
09-04-2022, 05:25 PM | #1813 |
And a picture to go along with the lap time. I guess jumping the "jump" is inevitable at speed.
09-06-2022, 11:42 AM | #1814 | |
Drives: SS1LE Join Date: Dec 2021
Track= Pocono International Raceway N/S Option 2 (2.26 Miles)
Elapsed Time = 1:41.22 Year / Model / Trim = 2022 Camaro SS 1LE 6sp manual Date = 8/15/2022 Tires = OEM wheels and tires (Goodyear) Mods = GM track alignment and DTC60 pads and SRF brake Fluid |
09-06-2022, 02:17 PM | #1815 | |
09-07-2022, 12:55 PM | #1816 | ||
Drives: 2013 C6Z06 Join Date: Nov 2016
Provoste agreed with this approach, just look at his 2 Watkins Glen Times. Hell that was same day same car different tires! There may be other cases of this too. You clearly just deleted Travis's previous SC3 time from the list.
Old Ride: 2016 Callaway SC630 Camaro SS
09-07-2022, 01:48 PM | #1817 |
Driver for Hire
For clarity, I didn’t just delete Travis’ multiple entries, I went through and did a quick scrub of several multiple entries. I may have missed some, but there weren’t many.
I like some of the ideas here. I am open to suggestions. I like the idea of top-10 lists as well. I will add and update some of the times that I haven’t yet, but lately have been slammed. I just wanted to make sure there was no misconception. I have no ill-will towards Travis and didn’t isolate him only. He has great points.
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21 2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel |
09-07-2022, 03:07 PM | #1818 | |
09-07-2022, 04:45 PM | #1819 | |
If we are adding rules about multiple entries for the same track and driver, I'd suggest adding them near the top of the first post. At the moment, I feel the rules are a bit unclear, arbitrary, and inconsistent with the original intent. According to the first post, "This thread is intended to be fun, informational & educational". Choosing to not add entries members would like posted and deleting previously approved entries seems to directly contradict the "informational & educational" part. If there is a need for fewer entries, let's at least do it in a way that makes sense. I previously mentioned limiting each track configuration to 10 entries, but even that has the downside of every entry eventually being occupied with modified cars. Requiring a lap video might be a good start if the purpose is indeed to be informational and educational. I think Jason's suggestion of allowing otherwise duplicate entries for both sub-200 TW and 200+ TW also makes sense. To be honest though, I don't understand the need to limit it at all. It has worked the way it is for years with very few issues.
09-07-2022, 07:13 PM | #1820 |
Drives: Chevy Camaro Join Date: Nov 2019
Agree and the thought of limiting this to a top ten is not a good idea for the masses. The list is a great source for comparison between the different drivers/cars/tracks/mods...etc. It would be a shame to lose this. Maybe some of the folks here that would like to change the current process should volunteer to assist with the upkeep of the data.
