Roto-Fab
Old 02-27-2020, 10:46 PM   #1
CHRI55
Streetkingz_chri55
CHRI55's Avatar
Drives: 2012 2ss/rs
Ported heads vs aftermarket
Currently I'm cammed using the gpi ss4 nfc cam in a l99.. looking into heads
Stuck between porting stock heads, prc 260s or brodix bp br heads
Going to go 416 maybe next year and end up going centri
I hear a lot about ported and prc. But being on a little budget is killing me. I also see brodix is priced good but dont see many ppl using them
Any experience or info is appreciated
CHRI55 is offline   Reply With Quote
Old 02-27-2020, 10:55 PM   #2
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
I had PRC port and mill my stock ones. Seems to have worked well.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 02-28-2020, 12:23 AM   #3
CHRI55
Streetkingz_chri55
CHRI55's Avatar
Drives: 2012 2ss/rs
Wthat did it cost
Old 02-28-2020, 01:09 AM   #4
IWANTA(ss)
IWANTA(ss)'s Avatar
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14
If I was you man I’d call GPI your in Greenville too that’s a easy drive for you
02 Stepside Silverado
05 ZX-10
13 1LE
14 Nightrod Special
IWANTA(ss) is offline   Reply With Quote
Old 02-28-2020, 05:05 AM   #5
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
I am using GMPP cnc heads. I had them milled as well. Working pretty good for me. I got a killer deal on them new.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 02-28-2020, 06:25 AM   #6
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
If you are going FI I would save your money and put it elsewhere. Maybe it makes a bigger difference on a 416 but with FI the stock heads flow plenty well, cheaper to drop a pulley size if you want extra flow. What are your power goals? If its reasonable you will get there with the stock heads.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
Old 02-28-2020, 09:16 AM   #7
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
If you are ultimately going FI, stick with the stock heads unless you are going to do a max effort money be damned set-up. Look at many of the FI builds 1000hp is achievable on stock heads and intake. You don't even have to go to a 416. Success depends on a well thought out combo. Put the money you would spend on heads into forged pistons and rods. Or, as at least three of us on this board are going with - iron LY6 forged setups for FI and people have taken these into the 8's on the track. Don't sweat the 100lb weight penalty for iron unless you are road racing.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 02-28-2020, 01:19 PM   #8
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
If you are set on heads, great advice here. I have a set of GPI's heads and they are a work of art. These guys are top notch!
gunchamp is offline   Reply With Quote
Old 02-28-2020, 02:17 PM   #9
IWANTA(ss)
IWANTA(ss)'s Avatar
Whats the biggest difference in the car when you added the heads? Sending my car up soon for porting milling and flycutting
05 ZX-10
13 1LE
14 Nightrod Special
Old 02-28-2020, 03:13 PM   #10
CHRI55
Streetkingz_chri55
CHRI55's Avatar
Drives: 2012 2ss/rs
I wanted to go 416 before going fi... and 700 800 to the wheel or close
Old 02-28-2020, 03:15 PM   #11
CHRI55
Streetkingz_chri55
CHRI55's Avatar
Drives: 2012 2ss/rs
I'm going 416 because I really don't know how long itll b before I go fi. I know I will eventually but the boost community in my area is STRONG.. so I wanna take advantage of the na class while u can
Old 02-28-2020, 03:22 PM   #12
Kelly@PCMofNC
Drives: 2010 RS/SS
I would suggest Advanced Induction for porting/polishing your heads. They have a great 280cc package that usually does 25-30rwhp for us consistently. That is pretty much the only place I use for headwork on any LS.
Kelly@PCMofNC is offline   Reply With Quote
