02-05-2020, 04:58 PM | #1 |
Drives: 2017 Camaro ZL1 Join Date: Nov 2016
How long can I wait?
Installing LT headers with HF cats next week, how long can I go before tuning? am installing on saturdat and have to drive to work 4 days before I can get it done. Is that OK?
02-05-2020, 05:12 PM | #2 |
You're gonna have to see how it runs. It's not a matter of waiting, it's if it will
run good enough to use. If it drives fine, you can wait as long as needed. If it won't run right, then you can't really wait. You will have a check engine light. If you get P0430 and P0420, then the fuel mix will be a little rich. As long as the car drives. You don't want lean conditions for too long, but 4-days should be fine. |
02-05-2020, 05:51 PM | #3 |
Drives: 2015 1LE Join Date: Oct 2016
Yeah you'll be fine, the car will adjust until it goes out of range and can't adjust anymore, but that won't happen.
02-05-2020, 06:21 PM | #4 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
You should be fine
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
02-05-2020, 11:16 PM | #5 |
Drives: 2011 Chevy Camaro SS Join Date: Jun 2017
You should be alright. Just don't go WOT or launch it.
02-05-2020, 11:23 PM | #6 |
keep your foot out of it. Fuel trims should handle the rest.
02-05-2020, 11:46 PM | #7 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
You good. Ran mine for a month before getting my cam and tune etc etc..
02-06-2020, 12:01 AM | #8 |
Drives: 5th Gen L99 Join Date: Nov 2017
I ran mine for a month and it never popped a CEL.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
02-06-2020, 03:53 AM | #9 |
Thank you for all the responses
02-06-2020, 04:00 PM | #10 |
Started#gottalovethatblue
You'll be fine as other have said. Stay out of the throttle too hard (tough I know) until you get the tune and then let her rip.
02-06-2020, 05:19 PM | #11 |
Drives: HHR Join Date: Dec 2015
Dont wait too long though, running really rich and allowing unburnt fuel into the cats can shorten their life.
02-09-2020, 05:46 PM | #12 |
USA-1
Have you thought about getting a tune from RDP Motorsports/DynoSteve? He's like $400 for lifetime tunes, so for instance, you can get this tune, and then if you get gears in the future you get a free updated tune. Now, he won't do tunes for big cams or forced induction, but otherwise everything else.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
02-10-2020, 03:45 AM | #13 | |
02-10-2020, 05:30 PM | #14 |
USA-1
So...you say that NOW...but what happens when you decide to get something else? You'll be paying for a tune again. It's your money. :P
