Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 06-25-2018, 11:21 AM   #15
saluki
Drives: 2017 Silverado
Originally Posted by qcman View Post
OP mine runs there more often than not. I too heard the "my trans never goes over 180" speak on here. I got paranoid and added a cooler at my dealer even though they said my temps were fine and it still runs the same temps in traffic. It cools faster afterward when moving which is better I think.
But here is what I figured out with my car. I rarely use the AC so my coolant gets up to about 105C or 221F then the car cools down to around 95C once the thermostat opens. And then back up it goes cycling in temperature. So the trans cooler in the radiator is being heated by the coolant....
If I run the AC my car never goes over 93C or about 200F and my trans stays at about 180 pegged. Now it could be the fans blowing over my trans cooler but I doubt its that. So maybe try what I'm saying to see if yours behaves similar. I think the cooling system is set up to run better with the AC on overall.
my trans only stopped running over 180 when I put a 160 Tstat in it. and that's because the water temp dropped by 20 degrees.
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis
saluki is offline   Reply With Quote
Old 06-25-2018, 02:17 PM   #16
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
Exactly! That was my point its the water temp doing it not so much the trans. thx for chiming in with how a thermostat change affects it.
qcman is offline   Reply With Quote
Old 06-26-2018, 01:43 AM   #17
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
Well doesn’t our fans come on when we turn on the AC?
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 06-26-2018, 07:08 AM   #18
saluki
all that damn radiator does is warm the damn transmission up and keep it and engine temp.
Old 06-27-2018, 10:43 AM   #19
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Low speed comes on once the AC is turned on.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 06-27-2018, 02:46 PM   #20
qcman
qcman's Avatar
Yup agreed Saluki transmission cooler in the radiator my ass lol....
Old 06-27-2018, 02:50 PM   #21
qcman
qcman's Avatar
Yes they do and my point was if people are saying what their trans temps are they should say AC on or AC off when noting the temperature because they can differ quite alot just between AC or no AC
Old 06-27-2018, 04:34 PM   #22
jc615
jc615's Avatar
Drives: Camaro and Sierra
I don’t run the AC with my temps
jc615 is offline   Reply With Quote
Old 06-27-2018, 05:20 PM   #23
qcman
qcman's Avatar
You're modified though right? Like a stall and bigass cooler? Never goes above 180 even in stop and go? Traffic too?
Old 06-28-2018, 01:26 AM   #24
Athletics101
Drives: 5th Gen L99
My pic was AC off. I did a trans service dropped the pan and changed filter also added JRE dipstick. It seemed to run a tad cooler today. I will get to drive it farther Friday and maybe install my cooler this weekend.
Old 06-28-2018, 10:25 AM   #25
qcman
qcman's Avatar
Try driving it around in traffic with the AC on as is and see what you get. I'll bet it stays closer to 180.... I'm not saying you shouldn't go with a cooler but I know it didn't change much on my car although it was a modest sized cooler they added too. With the cooler my coolant still runs the same temp as before but the trans does cool faster once the car gets moving.
The trans runs hotter than we all liked to see back in the old days but the trans fluid is so much better now so it really isn't an issue at all.
Old 06-28-2018, 11:11 AM   #26
WoodBoss
"Old School"
Drives: 2010 2SS L99
I have never seen my temp go above 180
WoodBoss is offline   Reply With Quote
Old 06-28-2018, 01:01 PM   #27
Athletics101
Drives: 5th Gen L99
Ill try it and see how the AC effects it. Is your trans tuned?
Old 06-28-2018, 02:51 PM   #28
qcman
qcman's Avatar
I'll try it and see how the AC effects it. Is your trans tuned?
Yes I am tuned but it was the same way stock so the tuning didn't affect it. I'm curious if you find it similar to mine.
