Old 01-20-2021, 11:25 AM   #15
ddivinia
Drives: 19 ZR1 20 350R Wife -> 24 ZL1 Vert
Originally Posted by Ksdaoski27 View Post
What kinda discount can you get when ordering?
I get GM Supplier discount. Only looking at liek $4K. I think I may can do better.
D.
ddivinia is offline   Reply With Quote
Old 01-20-2021, 11:28 AM   #16
ddivinia
Originally Posted by puppykat33 View Post
careful with the car cover mine did more damage than the cover was worth in windy applications
Car will be kept in doors with an indoor cover.
D.
Old 01-20-2021, 11:30 AM   #17
ddivinia
as far as the oil and diff look at the sticky at the top of this forum great info in it.... and the manual trans fluid. from my research i plan on changing the GM stuff over to the tremec HP MT fluid when i get around to changing it.
https://www.tremec-store.com/product...smission-fluid
Good sticky for sure. I am going to stick with GM stuff and just change it often.
D.
Old 01-20-2021, 11:31 AM   #18
ddivinia
Originally Posted by LT4Greg View Post
Don’t know if the jack pads from ZL1 Add ons will fit a vert and change the oil early if you want.
They make them for the vert.
I will order some.
D.
Old 01-20-2021, 11:32 AM   #19
ddivinia
That exposed carbon hood insert looks real good and the dash insert too. The first owner of my ZL1 didn’t get the dash insert but the hood insert.
Yes they do. The dash one is pretty easy to swap I hear.
D.
Old 01-20-2021, 11:34 AM   #20
ddivinia
Originally Posted by Scottyz View Post
Being a black car I would seriously look at getting some ppf. At the very least at the areas of impact like the front of the car and the area in front of the rear wheels. Also, to make it easier to clean the rims, I would have them ceramic coated as well as the calipers. This will help big time in the cleanup of the rims.
Car cover? Is the car going to sit outside or garage kept? If garage kept then GM offers some really nice indoor covers.
ZL1 add on jack pads. I tightened my attachment set screws just enough that I can take them on and off when I put the car in the air. Takes under a minute to take them on and off. Some guys leave them on. I keep mine stored in the trunk in case I do need them. They are nice pieces so it keeps them clean too. And also, you never have to wonder if they have contacted anything and are about to fall off the car.
I have not had a good experience with PPF. I am looking at fender extensions to help cut it down.
Indoor car cover.
ZL1 add on jack pads for sure. I have some magnet ones for my V now but these clamp on ones look pretty good.
Thanks,
D.
Old 01-20-2021, 11:34 AM   #21
ddivinia
Originally Posted by Realist View Post
Gonna look great and manual too, nice. Both a ZL1 and GT350R is even better. Congrats and be sure to post some pics!
Will do.
D.
Old 01-20-2021, 11:35 AM   #22
ddivinia
Planning on tint all the way around will help big time on the heat.
Color correction and ceramic all the way around and the wheels will make life easier.
D.
Old 01-20-2021, 11:42 AM   #23
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Definitely D get some tint on those windows. It looks good and makes a difference especially if you get ceramic tint.
Old 01-20-2021, 11:46 AM   #24
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
D.
I did my windshield too. Something like 75%. Helps big time.
Old 01-20-2021, 12:19 PM   #25
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Do your first oil change at 500 miles then do the second oil change and all of the other fluids at 1500 miles.
Old 01-20-2021, 12:42 PM   #26
LT4Greg
LT4Greg's Avatar
D.
I just don’t want to spend around $500 on the dash insert. It’s nice but not that nice if you know what I mean.
Old 01-20-2021, 12:44 PM   #27
L78toLT1
L78toLT1's Avatar
I would add a skip-shift eliminate harness to your shopping list. Others will probably chime in to report that you can learn to drive around this feature, but why change your behavior when you can change the car's for around fifteen bucks and five minutes. You can turn it off in the tune, but I wouldn't do that due to warranty concerns
Baby Blue
Old 01-20-2021, 01:06 PM   #28
ddivinia
The drive home will be like 820 miles.
Could have it done on the way home but may just have the stuff waiting and do it when I get it home.
Heck, maybe do them all at 1000 and again at 3000.
D.
