Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 01-14-2021, 10:54 PM   #1
Doc_Scott_PT
Drives: 2021 ZL1 stuck at 1100, GMC, Cruze
Kooks Green Cats question
I'm looking at a bolt on ported blower build, no meth, no cam, no e85, with kooks headers, 2.30 pulley, and new heat exchanger with larger coolant tank at around 650/700 who, how well will the green cats hold up to that power and to being daily driven? I need reliability more than anything else.
Doc_Scott_PT is offline   Reply With Quote
Old 01-15-2021, 02:02 AM   #2
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Fine. I would be concerned when you go over 800rwhp
Old 01-15-2021, 07:40 AM   #3
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
If you are going to run cats, those are the ones to have. At your power level they will be fine.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 01-15-2021, 08:00 AM   #4
Z OH 6
Z OH 6's Avatar
Drives: 2021 Red Hot ZL1
They will hold up just fine. My car makes more power than that with Kooks 2" headers and green cats and its a daily driver.
2021 Camaro ZL1 - Red Hot A10 - Vengeance Racing Stage III - 678whp SAE/697whp STD on pump 93
Old 01-15-2021, 08:04 AM   #5
hawk02
Coupe Newbie
hawk02's Avatar
Drives: 2017 Mosaic Black Metallic ZL1
If you need reliability more than anything else, I don’t understand why you want to mod the car? Keeping the car stock gives you the most reliable vehicle plus keeps your power train warranty intact.
Old 01-15-2021, 08:36 AM   #6
L78toLT1
L78toLT1's Avatar
Green cats will be fine with your proposed mods. In fact, you would most likely be ok with the standard Kooks cats. I've been running the "high flow" cats for 10k miles with the mods in my signature. I do run e60 almost exclusively which helps keep things cool. I read that std cats are good for 1500 F, greens 2300.
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels/6 piston Brembo's/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson Heartbeat with 85mm pulley/Full LT4 fuel system/JMS boost-a-pump/Skidmark Garage E85 Sensor/JRE Smooth Idle Cam/GPI piston/rod kit /APR main, head, balancer bolts/Kooks 1 7/8 headers with high flow cats/JRE remote tuned
Old 01-15-2021, 02:39 PM   #7
Markoz28
Drives: 18 ZL1 nightfall grey A10
Kooks cats should have no problems.
Nice build BTW. Any 103 TB and Big Gulp?
Markoz28 is offline   Reply With Quote
Old 01-15-2021, 02:49 PM   #8
Repman
Drives: 18 Black ZL1-1LE
If you road race your car at that level they will not hold up , ask me how I know !
Repman is offline   Reply With Quote
Old 01-15-2021, 03:32 PM   #9
CS10SS
CS10SS's Avatar
Drives: 2017 ZL1 A10
are you speaking about the - Green Cats? or Kooks Cats?
What would classify as road racing? Time? Track days? Speeds?
2010 2SS/RS M6 455rwhp - sold
2013 ZL1 M6 720rwhp - sold
2017 ZL1 A10 - stock... for now
CS10SS is offline   Reply With Quote
Old 01-15-2021, 04:41 PM   #10
Z OH 6
Z OH 6's Avatar
There's no reason to believe the green cats will not hold up if the car is tuned correctly, I believe each cat is rated to 400hp per cat so its really only above 800hp that they might start to become restrictive. That being said, I ran stock cats on my 1000hp Hellcat for almost 2 years without any issues and those were stock. The Kooks Green cats are made by GESI and are the best available, they are not cheap and they are very durable.
Old 01-19-2021, 12:15 AM   #11
Doc_Scott_PT
Another way of saying "I want more power conservatively as necessary".
Old 01-19-2021, 12:17 AM   #12
Doc_Scott_PT
Yup and yup! Basically bolt on power, good horsepower without affecting drivability, with more cooling and can road trip the car cross country.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
